I was looking for a cheap offtheself sensor (battery powered) to add them around my house and dump data into a database.
This things costs around 5€ in aliexpress, i cant wrap my head around how can they make them so cheap, the BLE chip alone in digikey costs 4€
https://es.aliexpress.com/item/1005001676531931.html
Or 10€ from the original store
https://buy.mi.com/es/item/3204600074
I guessed & decoded the BLE characteristic this Sensors use to transmit Temperature humidity and battery voltage.
Now im reading 9 of them at the same time with my raspiZero and visualice everything with nodered
looks like you have done very hard work for this it looks amazing thanks for sharing this with us keep up the good work also have projects like this but they are not that hardworking
