More Info:
Features:
- CPU: Z80 running at 7.3728 MHz
- Interface: Two high-speed serial ports at 115200 Baud. One with a fully compatible RS232 driver.
- Disk: 64MB or 128MB Compact Flash card support, containing 8 or 16 logical drives, respectively.
- RAM: 64K Byte
- ROM: 16K Byte, switched off when CP/M active.
- Resets: Both cold (full reset) and warm reset (used to return to CP/M prompt) circuitry
- CP/M support: 2.2 with included software. More information about CP/M.
Schematics:
It's able to use internal or external clock and internal or external power supply. Also the peripheral bus can expand it by using other boards via Baffa Backplane.
Augusto Baffa
Keith
Just4Fun
