Hackaday.io Hackaday.io
Sign up Log in
3D Printed Flying wing FPV Drone
In this project, the objective was to build a FPV flying wing with over 700mm wingspan that could be printed under 24 hours.
kK+
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.4k views
1 comments
824 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
2.4k
1
824
18
Team (2)
  • kK+
  • rover109rover109
Join this project's team
  • Website
MISC
completed project
3d printing drone 3D Print 3d FPV FPV Drone flying wing 3d printed drone
This project was created on 05/30/2022 and last updated 4 years ago.
Description
In this project, the objective was to build a FPV flying wing with over 700mm wingspan that could be printed under 24 hours at 0.2mm layer height and is easily Assembled. The drone comprise of only 8 parts. You do not need a flight controller or anything else to run FPV on this model. 3D Printed Parts -2 Elevons -2 Wing Tips -2 Wings -1 Fuselage -1 Canopy Electronics - 2 x Servos Motor 9g https://amzn.to/3H0UXK0 - A2212 Motor (1000kv or 2000kv) https://amzn.to/3xfTElX - 1 x 30 Amps ESC https://amzn.to/3xmMmxV -Micro FPV Camera Kit (with transmitter and receiver) https://amzn.to/3GW10zj -RC Transmitter/Receiver https://amzn.to/3Mw279T -6045 Propeller https://amzn.to/3mkzVfR Tools -3D Printer (With one Axis larger than 250mm) https://amzn.to/3NvBZxe -Hot glue Gun & Sticks https://amzn.to/3NXmv5c -Cyanoacrylate glue https://amzn.to/3aAUoKo -RC elevon rods https://amzn.to/3MkCY24 Checkout Build Video at: https://youtu.be/7MNrspOFYNY
Details
Files
Wing 1.stl
Standard Tesselated Geometry - 4.19 MB - 05/30/2022 at 23:37
Download
Wing 2.stl
Standard Tesselated Geometry - 3.84 MB - 05/30/2022 at 23:37
Download
Tip2.stl
Standard Tesselated Geometry - 476.35 kB - 05/30/2022 at 23:37
Download
Tip.stl
Download
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Roberto A. Foglietta wrote 01/22/2024 at 15:21 • point
Hi @K+ and @rover109, where I can find the missing files?
2021 Hackaday Prize
An almost completely 3D-printable shredder that can be used to shred 3D-prints ;-)
Project Owner Contributor
brian-brockenBrian Brocken
Convert your images into lithophanes and impress your loved ones!
3D Printed Lithophane Lamp
neeraj-raneNeeraj Rane
Aluminum 3D printer made of Actobotics components.
18" x 15" Aluminum 3D Printer
eviscerate-coreEviscerate Core
A bold undertaking to create an RC truck entirely from printed parts (With the exception of electronics obviously)
3D Printed RC Truck
jacob-bosargeJacob Bosarge
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "3D Printed Flying wing FPV Drone", please tell us the reason.
Send message
Remove Member
