Nesting
03/22/2026 at 13:26 • 0 commentsI just wanted to let everyone know that the great tits have started building their nest again. Instead of showing the usual dashboard image I though I could give a graph showing the birdhouse usage over the years. You can see that in 2023 there was a second brood. The duration for the second brood was much shorter compared to the first because the birds where simply reusing the already existing nest (didn't have to build their own). I have learned on Wikipedia that the great tit only does a second brood if there is enough caterpillar prey available.
Batteries
03/03/2026 at 08:59 • 0 commentsToday I replaced the LIR2032 coin cell battery (luckily the birds have not started nesting yet) . This one started leaking and it had also popped out of the holder when I opened up the enclosure. I'm done using the coin cells. The 100 mAh LiPo packs are more robust and dependable 😀 .
Maintenance
07/10/2025 at 05:58 • 0 commentsAfter the birds left and no new birds started breeding I took down the birdhouse to clean/check the condition of all components. Putting a cork floor on top of the scale turned out to be not so good an idea. The birds used their claws in winter time to turn the cork floor into crumbles. I have replaced the cork now with linoleum (hope this will be more durable). And I have added another coat of linseed oil to protect the wooden panels of the birdhouse. This should hopefully prepare the birdhouse for yet another year out in the field :-) .
Gone
05/20/2025 at 05:05 • 0 commentsThe nestlings have left the bird house late afternoon on May 19th. This is about a week earlier compared to what I expected (these guys are fast :-) ). I'm curious to see if there will be a second brood this year.
Chicks
05/08/2025 at 07:27 • 0 commentsIt looks like the eggs have hatched after about 16 days of breeding. On May 4th the weight inside the birdhouse started going up. The female will warm the hatchlings and both female and male will feed the young ones from now on. According to Wikipedia the young birds should be ready to leave the nest in about three weeks time (end of May/beginning of June). And it still amazes me how fast all of this is happening :-) .
Easter
04/22/2025 at 13:48 • 0 commentsAfter bringing in about 50 grams of nesting material the female now (19th of April) seems to be almost permanently inside the birdhouse. To me this looks like it has laid the eggs and now only leaves the bird house for short intervals to find something to eat. The eggs should hatch in about 2 weeks time. I'm curious to see if the scale can detect the difference once the eggs hatch :-) .
Construction
03/30/2025 at 07:39 • 0 commentsI just wanted to let everyone know that the birds have started building their nest again. They started bringing in material around March 26th which is about a week later compared to the years before.
Coin Cell
10/31/2024 at 07:44 • 0 commentsA couple of days ago the birdhouse stopped sending data. At first I thought they where doing maintenance on the LoRaWAN gateways because it started on a Friday evening. After a while I noticed that whenever the sun came out the birdhouse tried doing a LoRaWAN join. That told me that there was probably an issue with the battery because the solar panel was still working. Yesterday I took down the birdhouse. The LIR2032 coin cell was still fully charged at 4.0 volts. It looks like the coin cell holder is the problem (mechanical issue?). Maybe it is not designed for the temperature changes out in the field. Just in case I replaced the coin cell and put the birdhouse back up again. It has been working again without incident for the past twelve hours. I will replace the coin cell with the old LiPo pack (JST connector) should this happen again.
Nightly
10/16/2024 at 10:44 • 0 commentsThe birds started coming back to the new birdhouse on October 12th. There seems to have been a competition for who gets to stay over night (at one point the scale detected two birds inside the birdhouse :-) ). You can also see the battery lose a few milli volts during the night. This is due to the new LIR2032 coin cell that powers the electronics. It only has a capacity of about 40 mAh compared to the 100 mAh LiPo pack used previously. I'm curious to see if the LIR2032 is enough to get the birdhouse through the winter (I can always put in the old battery if needed).
Update: I just passed the birdhouse on my way home. There was a flock of about half a dozen young birds hopping around the birdhouse flying in and out. I'm no bird expert but maybe there was a realtor there trying to auction off the place (these little guys always make me smile :-) ).
Version 3
07/11/2024 at 15:59 • 0 commentsVersion 3 of the birdhouse is almost finished. I will do some software testing over the next few weeks until I will replace the current birdhouse in September. There are some nice features in v3 like a scale with the NAU7802 ADC and two load cells (better mechanical stability). The sides, back and top panel are now glued together to provide better moisture protection. And I have replaced the veneer on top of the scale with cork. Cork is very flexible, naturally water proof and provides good temperature insulation for the birds sitting on top of the scale in winter. The only drawback is it smells a little bit of old wine cellar (I hope the birds will not mind ;-) ). I would also like to keep this birdhouse running for more than a year (the previous versions where only out there for about a year each). I will still clean out the birdhouse/do maintenance whenever needed but I'm curious to see how the birdhouse will hold up over a longer period of time. If you are interested in any further details then please check out the Version3 zip file.
Jan Schlieper
