The application will be made for phones. It should have two main modes.
Mode 1 : Information
The application will display what degree of risk of avalanche a mountain area has. If an avalanche happens at the moment the app is used, it will immediately be displayed.
In order to be aware of avalanche risks in real time, the app is connected wirelessely to multiple sismometers present in designated mountain areas. This way, the rsik of avalanches will be calculated in real time.
Mode 2 : Watcher
Before going out skiing, the user input in the app the location of their ski session. In that case, the app will stay cconnected to the sismometers posted in the area chosen by the user. When high risks of avalanche are detected, the app will immediately warn the user through vibrations or sound. (Alternatively, we plan to add a wristband for warnings. It would be connected to the app and when a warning has to happen, the wristband wil vibrate instead of the phone. This way the user can be easily warned even in the middle of skiing where checking their phone isn't easy)
