Baffa-X: MSX1 Compatible Computer
Project codename "Baffa-X" is a set of boards to make a MSX1 Clone for Baffa-2 Homebrew Computer
0 followers
Baffa-X is a project to transform Baffa-2 into a MSX1 Computer. It's based on Brazilian Sharp's HB-8000 (Hotbit) schematics and Beer 202 IDE Board. The projects also uses the original Z80 CPU, 64KB RAM, Clock and TMS9918 Boards from Baffa-2.
Baffa-2 is an educational and personal project with the aim of understanding how computers work through 80's 8-bit commercial machine designs. It has a modular concept with boards that can be combined to develop your own design and configuration.
More info: https://hackaday.io/project/183266-baffa-2-homebrew-microcomputer
After the Baffavision project and reading some notes by J.B. Langston, I realized that I could continue studying to make Baffa-2 an MSX clone. I already had CPU, VDP (video card), PSG (sound card), clock and base memory (64KBs), so I just had to put it all together with a parallel peripheral interface (PPI) msx.
In Brazil, we only had contact with MSX1. There were some national kits to upgrade it to an MSX2 but most people didn't upgrade at the time. For this reason, I thought of creating a clone of what we had contact with and based it on the schematics of one of our main machines: Sharp's Hotbit (HB-8000).
I still plan to add a serial via wifi to be able to connect it to the internet and the printer interface card (using DB29 connector). In the future I also see that it is possible to create a memory mapper and a VDP using the v9958 chip, which will allow compatibility with MSX2.
I am proud to say that this project is sponsored by PCBWay.
Other Acknowledgments:
View project log
