hinge_top_right_rev3.stlPrint 1xStandard Tesselated Geometry - 14.43 MB - 10/03/2022 at 02:01 |
hinge_base_left_rev3.stlPrint 1xStandard Tesselated Geometry - 10.76 MB - 10/03/2022 at 02:01 |
hinge_top_left_rev3.stlPrint 1xStandard Tesselated Geometry - 14.68 MB - 10/03/2022 at 02:01 |
hinge_base_right_rev3.stlPrint 1xStandard Tesselated Geometry - 10.64 MB - 10/03/2022 at 02:01 |
hex_foot_rev3.stlPrint 4xStandard Tesselated Geometry - 4.27 MB - 10/03/2022 at 02:01 |
top_edge_fill_derived_rev3.stlPrint 4xStandard Tesselated Geometry - 506.35 kB - 10/03/2022 at 02:01 |
corner_piece_bottom_rev3.stlPrint 2xStandard Tesselated Geometry - 1.33 MB - 10/03/2022 at 02:01 |
corner_piece_top_rev3.stlPrint 2xStandard Tesselated Geometry - 1.57 MB - 10/03/2022 at 02:01 |
faceplate_rev3.dxfCut 1x of 3mm Acrylic or other material.AutoCAD DXF - 181.87 kB - 10/03/2022 at 02:01 |
bottom_edge_fill_derived_rev3.stlPrint 4xStandard Tesselated Geometry - 415.09 kB - 10/03/2022 at 02:01 |
case_top_flatpattern_rev3.dxfCut 1x of 2.5mm Thick Aluminum and get bent.AutoCAD DXF - 133.31 kB - 10/03/2022 at 02:01 |
case_bottom_flatpattern_rev3.dxfCut 1x of 2.5mm Thick Aluminum and get bent.AutoCAD DXF - 137.86 kB - 10/03/2022 at 02:01 |
bottom_plate_rev3.dxfCut 1x of 3mm Acrylic or other material.AutoCAD DXF - 103.68 kB - 10/03/2022 at 02:01 |
computer_cover_rev3.dxfCut 1x of 3mm Acrylic or other material. Translucent recommended.AutoCAD DXF - 91.95 kB - 10/03/2022 at 02:01 |
battery_plate_rev3.dxfCut 1x of 3mm Acrylic or other material.AutoCAD DXF - 101.85 kB - 10/03/2022 at 02:01 |
