Collectible Card Game Counter
I had old hard drive platters sitting around, a bored evening, and wanted to keep track of a MtG score.... :)
Like anyone who has worked as a tech in the IT industry, I have a ton of old parts laying around. Normally I use old Hard drive platters for things such as drink coasters or wind chimes, this evening I got the idea to make myself a new Magic the Gathering life counter. I used 3 platters, 2 of the same size and one smaller one from a laptop. I was not sure if this really qualifies as a hack, however I have been asked a few times to post this for others :) I am going to use a metal cap from the hardware store, the same kind you put on the end of a pipe, as the center piece. In order to keep the platters from sticking together I put a bit of masking tap on the bottom of the small platter and the middle platter. Tools required: Safety glasses Drill and drill bit of appropriate size Engraving tool or rotary tool with appropriate bit. I will post more as I finish this project. :) Cheers! ~Jessie
Tools used:
Diamond engraving bit for a dremel rotary tool
Dremel rotary tool
3/8" drill bit
Electric drill
Needle nosed pliers
Xacto knife
Pencil
Bow compass, for marking out angles
Game that I plan to use this counter for:
EDH MtG
http://mtgcommander.net/rules.php
  • 2 × desktop hard drive platter they should have a 1" center hole and be the same size
  • 1 × laptop hard drive platter
  • 1 × Hole plug, part # 13138 chrome hole plug with "teeth"
  • 1 × masking tape 2" wide
  • 1 × Vinyl Bumpers part # 158724 self adhesive type
  • Game night
    ThunderSqueak • 07/14/2014 at 00:49 • 0 comments
    My normal card game night was cancelled, so I had the evening to do something else.  I was sitting there and looking at my new EDH MtG deck and thinking "I wonder if I can make a life counter out of that stack of hard drive platters over there."
    This project took 1 evening, about 2 hours.
View project log
  • 1
    Step 1
    The first step was to decide what number I wanted to go up too, in my case I chose 159, this meant that the outer ring would need to be numbered from 0 to 15 and the inner ring from 0 to 9.  After marking on the old hard drive platters with a pencil, I used an xacto knife to scribe the numbers in.  This served two purposes, the surface is so smooth that pencil will just wipe off, and gave the rotary tool that I used something to follow.  Sorry about not having a picture of this step, I didn't think to take one :(
  • 2
    Step 2
    After I marked out the layout, I sat down with my rotary tool with an engraving bit.  Be sure to wear safety glasses, there will be small bits of metal flying off :)
  • 3
    Step 3
    I used the rotary tool to cut a small center point for the drill bit.  If you do not do this and are using a hand drill, there is a chance that the bit will walk across the surface of the platter, permamently marring it.
View all 7 instructions
