Data-To-SD
A small PCB that takes data (from the points on the PCB) and allows you to use an SD format
I actually am in to Nintendo 3/2ds hacking and am currently doing a hard mod on it (which is a project it in its own right.) To read the data from the NAND you must take a Micro-SD to SD Adapter and solder to the pins inside of it. I found this tedious and not clean. So as a first project for learning how to design a PCB I decided to make a Data-To-SD PCB. As it's my first I wanted a ground-work to start off with. So I took an Open-Source design (Under the Creative Commons 4.0 Share Alike Licence) by Aaron Weiss as a building block (Original Design here: https://easyeda.com/oshw/SD_Sniffer_Open_hardware-UoUcunFXf)
Under The Creative Commons Attribute ShareAlike 4.0 International: https://creativecommons.org/licenses/by-sa/4.0/
The original creation was edited for another use
No components needed to solder on (Except the wires you solder on the pins)
Has 2 layers needed to be printed (Top & Bottem)
SD_Sniffer.sch
Normal Version Schematic
sch - 71.51 kB - 02/13/2017 at 21:00
Download
SD_Sniffer.brd
Normal Version Board
brd - 306.40 kB - 02/13/2017 at 21:00
Download
SD_Sniffer_Hardmod.sch
Hardmod Version Schematic
sch - 67.38 kB - 02/13/2017 at 20:59
Download
SD_Sniffer_Hardmod.brd
Hardmod Version Board
brd - 96.10 kB - 02/13/2017 at 20:59
Download
  • And It's Done!
    coletonn02/13/2017 at 21:02 0 comments
    My first project ever is done! I will be selling these on Tindie soon, so if you want to buy some just get set.
View project log
