Hackaday.io Hackaday.io
Sign up Log in
Projekt NED-CPU
NEDCPU is a computing unit inspired by the first computers controlled by serial terminal commands, built on current technologies.
michalMichal
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
249
0
1
1
Team (1)
  • michalMichal
Join this project's team
  • Blog
scrapped project
hardware
arduino computer
This project was created on 04/30/2023 and last updated a month ago.
Description
The basic unit is built on the basis of the ARM MCU STM32F103C8, which communicates with the PC using a USB converter that simultaneously provides power. A micro SD card slot is connected directly to the MCU for data storage and retrieval. Furthermore, via a level converter (3.3V from MCU to 5V) on the I2C bus, the RTC module and three 8-bit gate modules PCF8574. One gate is used to control the 8 LEDs on the front panel and the other two are connected to the LPT expansion connector. The front panel therefore contains 8 LEDs, an expansion LPT connector, a RESET button and a switch for programming (MCU requires it)
Details
Files
projektNEDv1_2.ino
firmware v.1.2
ino - 65.22 kB - 04/30/2023 at 12:30
Download
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Multipurpose Wireless transceiver : RF, GPRS, Wifi, Bluetooth....
Project Owner Contributor
ESP32 Multipurpose Wireless Hub
eric-costeEric COSTE
CH341 is mostly used in memory programming and a dedicated programmer available. But there are many protocols supported by CH341 IC
CH341 USB-I2C
mit41301mit41301
This project demonstrate LabVIEW modbus control of the Amazon DROK Model ZK-SK90C
Power Module Modbus Control
mario-ninicMario Ninic
A DIY radio reconnaissance device
Software Defined Toolkit
p3rp0ulp3rp0ul
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Projekt NED-CPU", please tell us the reason.
Send message
Remove Member
