In searching for a pair of wearable hooves, I couldn't find any that wear comfortable to wear for any length of time. This design is made to have an ergonomic grip that you can comfortable put weight on, as well as a good grip for gesturing, prancing and... what-have-you
In order to be 3d printable, the hoof is 3D printed in 2 pieces which allows for minimal support material, and for the support material to be easily removed. This also allows for interchangeable designs eg with or without horseshoes. Assembly is simple, with two 8Gx40mm screws for each hoof.
This work is licensed under a Creative Commons Attribution-NonCommercial-ShareAlike 4.0 International License: http://creativecommons.org/licenses/by-nc-sa/4.0/
Files
horsehoof mk2 4.stl
Body of hoof
Standard Tesselated Geometry -
2.29 MB -
08/16/2023 at 02:45
Different sizes. at present, these are sized only for my hands, and due to the assembly hardware cannot be simply scaled up and down. I plan to upload several sizes, as well as a sizing guide. I'm not sure when this will be complete, but if you're interested let me know and I can prioritise it
More realistic frog - this is the v-shaped structure on the bottom of horse's hoof that is currently missing from the design
