- For the mirrors, we broke a disk in pieces that we then sticked on circles-shaped pieces of cardboard and to allow the user to move/rotate the said circles we glued a magnet to the cardboard and put the complementary magnet inside the box which allows the user to move freely the mirror and rotate it without it falling appart.
- The door to open the box also uses a magnet to keep it closed.
- The potentiometer is used for the screen's lighting.
-A photoresistor is used as the receptor of the laser for the said minigame.
The idea is actually very cool. I would like to manufacture such things. I recently downloaded the application myself, you can look here if you want. But everything is online for me. If I had such a box at home, then fortunately there would be no chapel!
