Attiny85 Keychain Dice
Attiny85 based electronic dice
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This little keychain is composed of an Attiny85 (SOIC 8), a button on the IO2 pin (pin 7), a CR2032 battery slot and 7 leds. With this device, you can simulate a dice, and with deep sleep mode, the keychain will work for many months.
To program this device you can use my Attiny Uploader with SOIC clamp.
How to program the board:
Arduino IDE board manager:
ATtiny25/45/85
VSCode platformio.ini:
[env:attiny85]
platform = atmelavr
board = attiny85
framework = arduino
upload_protocol = stk500v1
upload_flags =
-P$UPLOAD_PORT
-b$UPLOAD_SPEED
upload_port = //dev/cu.usbmodem1301
upload_speed = 19200
