Keyboard panel complete, Hardware build complete [ for now ]
09/03/2023 at 17:49 • 0 commentsThe keyboard panel was reworked, the 4 port USB hub was removed and in it's place the eth0 port was placed. A storage compartment was added to house a 1 tb ssd and rtl-sdr antennas. Supports were added to the keyboard panel to give it a more sturdy feel. Lastly I was able to find a Oni emblem and mounted it to the exterior of the case. I went with raspbian 64 bit for an OS and with all the additions I have made thus far and plan to make in the near future I feel will also try and burn a copy of the finished OS. The project is still ongoing.
Panels added behind screens / 7 port hub moved
09/01/2023 at 14:16 • 0 commentsPanels were added to hide wiring and clean things up a bit in the back. The panel which housed eth0/audio/extra USB and charging port was modified and now only houses the audio and charging port. The extra USB port is now going to connect to a 1tb SSD which will be housed under the keyboard panel. The eth0 port will also be mounted in the keyboard panel. I am now on to reworking the keyboard panel which will be comprised of multiple smaller panels with some storage for some tools and antennas. I am also going to add a emblem to the outside of the case, but that's last on the list.
Project status changed / Revisions to be made
08/21/2023 at 21:02 • 0 commentsAs the contest has ended and it literally only took me 2 weeks I want to put some actual time into revising some aspects of the build. I would like to rework the keyboard panel and do a better job of hiding some of the wiring, as well as move the placement of the 7 port usb hub.
Description expanded upon and github links added for software
08/08/2023 at 15:14 • 0 commentsThe description was expanded to include a list of software installed to date. I will still be installing a few more things before the 14th, so the list will continue to be modified until then. Github links were added to some repos that are installed.
Parts list and Photos updated
08/08/2023 at 14:17 • 0 commentsThe parts list was updated to include links to purchase parts in the descriptions.
The photos were updated, some pictures were deleted and descriptions were added to all photos to help with build instructions.
