At present, the "brains" of the device is a Samsung Galaxy s23 smartphone, connected via USB-C to a hub. The hub, in turn, is connected to a TeckNet Heavy Duty back-lit keyboard via a USB cable and is physically attached to it via silicon and Sugru. A 2600 mAh power bank that I picked up cheap a few years ago is also glued to the keyboard, and a metal brace is attached to both the keyboard and power bank, giving it some stability, as well as a place for the phone mount to attach (via magnets).
The hub has 2 USB-3 ports (one of which is dedicated to the keyboard, but that's OK), a TF card slot, an SD card slot, a USB-C charging port, and an HDMI port. Overall, the device is lighter than a notebook but more tactile than a glass screen, and sits very easily on my lap.
I had originally intended to attach both the USB hub and phone mount to the keyboard via some kind of tab-and-slot sliding mechanism (not unlike how Joy-Cons attach to the Nintendo Switch), but I couldn't find the hardware I would need to implement it. Still, if I do another one, I'd like to explore that as an option, making the whole device more modular (being able to swap out different USB hubs for different needs, and maybe alternate mounts, so I could use a tablet instead of my phone).
I built it over the past couple of years, and actually went through several updates along the way (improving the hubs and phone holster).
Of course, it's not perfect - it's not as durable as I'd like it to be, and it's not exactly easy to carry. My hope had been to mount the whole thing to either some kind of metal frame or plate (a la a hiking backpack, but smaller), providing some much need structural support (and stable grips to hold on to), but I could never find what I was looking for. Plus, I built it before my current obsession with mechanical keyboards, so while the keyboard is nice, it doesn't have quite the desired _click_.
But, all-in-all, it was a fun project to put together, and it's come in handy more thana few times (when I was between machines, or waiting on repairs).
