Pet Pot
Pet Pot - A Smart Desk Planter
Discover the "Pet Pot" - Your Stress-Relieving Smart Desk Planter for a More Productive Workday!
MainBody.stl
Standard Tesselated Geometry - 1.68 MB - 09/12/2023 at 15:14
Download
MountingBraket.stl
Standard Tesselated Geometry - 249.11 kB - 09/12/2023 at 15:14
Download
Pot.stl
Standard Tesselated Geometry - 200.18 kB - 09/12/2023 at 15:14
Download
Top.stl
Standard Tesselated Geometry - 145.88 kB - 09/12/2023 at 15:14
Download
Capacitive_Soil_Moisture_Senso_Lower.stl
Standard Tesselated Geometry - 185.24 kB - 09/12/2023 at 15:14
Download
View all 6 files
  • 1 × DFRobot Unihiker https://www.dfrobot.com/product-2691.html
  • 1 × Air Quality Sensor https://www.dfrobot.com/product-2251.html
  • 1 × Environment Sensor https://www.dfrobot.com/product-2528.html
  • 1 × Soil Moisture Sensor https://www.dfrobot.com/product-1385.html
  • 1 × 90 Degree Type C Cable https://amzn.to/3YZeyTP
View all 7 components
  • 1
    Introduction
    Introducing Pet Pot - Not Your Ordinary Planter!
    Have you ever wanted a plant that communicates with you? Well, that's exactly what Pet Pot is all about! Pet Pot is not just an ordinary planter; it's a smart planter with a unique personality.
    Pet Pot uses high-tech sensors to understand what's happening in its environment. It pays attention to things like temperature, humidity, soil moisture, air quality, UV index, and light intensity. And guess what? It expresses its feelings through emojis!
    Imagine this: If you forget to water the plant and the soil is dry, Pet Pot might display an angry or sad emoji animation. If the room gets too hot, it'll show a hot emoji. And when the lights go off, it'll put on a sleepy emoji. There are plenty of other emojis to discover, each telling you something different about your plant's well-being.
    But that's not all! Pet Pot doesn't just show emojis; it also gives you real-time information about the temperature, humidity, soil moisture, air quality, UV index, and light intensity in its surroundings. It's like having a personal weather station right in your plant pot.
    And here's the exciting part: We've gone a step further. We've created a system that stores all this real-time data in a MySQL database on the same device as Pet Pot. We've even set up a NodeRed server to create a user-friendly dashboard. This means you can access and analyze all the data using your everyday devices, like your phone or laptop.
    With Pet Pot, you'll not only have a healthy and happy plant but also a fun and interactive addition to your home. It's the future of plant care, and it's here to make your life greener and more exciting. Get ready to experience the magic of Pet Pot!
  • 3
    CAD Designing & 3D Printing
View all 13 instructions
