Festo CNC (conversion)
Converting a scrapped Festo CNC rig into a (hopefully) working CNC mill for milling (mostly) aluminium
Got hold of a Festo setup from the dumpster of a company. I've wanted a larger CNC mill for milling pieces in aluminium for various projects.
From the Festo website, it seems, that Festo makes its own servo motors and gearboxes for moving the gantries around. Unfortunately, the setup was without motors and controllers, so I want to use this with standard NEMA23/34 motors. However, measuring the mounting hole positions and the axis diameter (of the X-axis) it became obvious, that a bit more work is needed.
This project is the work in getting the Festo up and running with standard stepper motors and custom electronics/control software for getting that "3D Printing" experience : Insert USB stick with GCode and Press Play.
Having been standing outside, the Y Axis wasn't running smoothly. I worried, that I had to use a NEMA34 motor for driving this axis. Adding a 1.8 kg motor costing $200 wasn't on the top of my list, so I started looking into how, the Y Axis was constructed. Whereas the X Axis runs directly on the belt, the Y Axis seems to run using a magnetic transmission (for keeping dust etc. off the Y Axis belt). Designing a short arm, which could be screwed on to the Y Axis, I found, that it only required a 0.250Nm forced to move it. After cleaning and oiling the linear rails of the Y Axis, the axis ran much better and with much less force, making it more likely to be able to run using a standard NEMA23 motor.
I designed a demo fixture for a NEMA23 stepper motor with 1:3 gearing using Belts and Pulleys. PLA version seems to fit, except for a 2 degree slope, which has been compensated for prior to printing it in PETG.
Huge thanks to www.makersupplies.dk (Martin) for his suggestions on how to begin this work and material choices.
FirstMove1.mp4
First movement test
MPEG-4 Video - 1012.45 kB - 11/29/2023 at 22:38
Download
  • Additional features using the PuzzleBox32 Mini
    Henrik Sorensen06/02/2025 at 10:46 0 comments
    Besides obvious functionality of movement, switching to PuzzleBox32 Mini gives me:
    1. Higher resolution (32 bit vs 8 bit Architecture)
    2. Limit switches:
      1. Isolation of the limit switch from the controller board
      2. Power is supplied via the limit switch connectors
      3. Better noise resilience
    3. PWM/Enable output for Spindle control (gonna be converted to 0-10V externally)
    4. Aux port for mist control
  • CNC Controller Upgrade
    Henrik Sorensen06/02/2025 at 10:38 0 comments
    I've decided to update the CNC Controller from a custom Arduino based board to the PuzzleBox32 Mini (with external drivers and external PWM spindle control).
    The PuzzleBox32 is in back order (would have been a better choice), so I'll stick with the PuzzleBox32 Mini.
  • FINALLY WORKING!
    Henrik Sorensen05/02/2025 at 06:10 0 comments
    Finally done:
    1. All axis working.
    2. 1.5KW Spindle and VFD installed.
    3. Basic electronics (Custom CNC Controller, Stepper Drivers and PSU installed)
    4. Mist cooling/air assist mounted.
    5. Spoil board with thread inserts mounted.
    First pieces done.
  • IT'S ALIVE!!!!!
    Henrik Sorensen11/29/2023 at 22:36 0 comments
    Finally, I got the time to adjust the motor mount bracket and added a belt tensioner to it. Mounted the NEMA 23 motor and added the electronics (Arduino Uno + custom shield) + driver. Tested the Y axis movement using Candle. And it FRAKKIN MOVES!!!
  • Y Axis plate prototype done
    Henrik Sorensen10/21/2023 at 10:22 0 comments
    Got the Y Axis Stepper motor mounting plate printed in PETG and tested it. Now for testing the actual movement of the axis.
    Test setup is gonna be an Arduino, Stepper Motor driver, Power Supplies and a laptop.
View all 5 project logs
