canon_rotater_base.stl3D STL file for the canon rotater componentStandard Tesselated Geometry - 285.63 kB - 01/12/2024 at 13:33 |
canon_rotater_holder_L.stl3D STL file for the canon rotater componentStandard Tesselated Geometry - 59.75 kB - 01/12/2024 at 13:33 |
canon_rotater_holder_R.stl3D STL file for the canon rotater componentStandard Tesselated Geometry - 63.27 kB - 01/12/2024 at 13:33 |
target_gear_end.stl3D STL file containing the last element of the target's gearStandard Tesselated Geometry - 166.68 kB - 01/12/2024 at 13:11 |
target_gear_inner_cog_retainer.stl3D STL file containing the inner cog's retainer of the target's gearStandard Tesselated Geometry - 37.97 kB - 01/12/2024 at 13:10 |
target_gear_inner_cog.stl3D STL file containing the inner cog of the target's gearStandard Tesselated Geometry - 1.20 MB - 01/12/2024 at 13:10 |
target_gear_outer_cog.stl3D STL file containing the outer cog of the target's gearStandard Tesselated Geometry - 1.06 MB - 01/12/2024 at 13:09 |
target_gear_handle.stl3D STL file containing the last part of the handling part of the target's gearStandard Tesselated Geometry - 154.09 kB - 01/12/2024 at 13:08 |
target_gear_handle_inner.stl3D STL file containing the second element of handling part of the target's gearStandard Tesselated Geometry - 186.02 kB - 01/12/2024 at 13:07 |
target_gear_handle_sleeve.stl3D STL file containing the handling part of the target's gear(which make the rod handled Standard Tesselated Geometry - 204.96 kB - 01/12/2024 at 13:06 |
target_gear_piston.stl3D STL file containing thepiston of the target's gearStandard Tesselated Geometry - 72.84 kB - 01/12/2024 at 13:05 |
target_gear_driver.stl3D STL file containing the driver of the target's gearStandard Tesselated Geometry - 566.78 kB - 01/12/2024 at 13:04 |
target_gear_rod1_retainer.stl3D STL file containing moving rod's retainer of the target's gearStandard Tesselated Geometry - 37.97 kB - 01/12/2024 at 13:03 |
target_gear_rod1.stl3D STL file containing the moving rod of the target's gearStandard Tesselated Geometry - 728.99 kB - 01/12/2024 at 13:03 |
target_gear_base.stl3D STL file containing the base of the target's gearStandard Tesselated Geometry - 976.74 kB - 01/12/2024 at 13:02 |
rear_hull.stl3D STL file containing the rear part of the boat's hullStandard Tesselated Geometry - 77.33 kB - 01/12/2024 at 12:59 |
front_hull.stl3D STL file containing the front part of the down hullStandard Tesselated Geometry - 66.29 kB - 01/12/2024 at 12:57 |
mid_hull.stl3D STL file containing the middle of the down hullStandard Tesselated Geometry - 120.98 kB - 01/12/2024 at 12:56 |
extremity_floor_hold.stl3D STL file containing one of the holds that will hold the boat to the floor (extremity one)Standard Tesselated Geometry - 2.23 kB - 01/12/2024 at 12:55 |
middle_floor_hold.stl3D STL file containing one of the holds that will hold the boat to the floor (middle one)Standard Tesselated Geometry - 6.92 kB - 01/12/2024 at 12:54 |
grand_trapdoor.stl3D STL file containing the grand trapdoor, which will be at the center of the deck.Standard Tesselated Geometry - 39.93 kB - 01/12/2024 at 12:48 |
canon_lazer.stl3D STL file containing the canon, which will contain the lazer pointer afterwards.Standard Tesselated Geometry - 297.74 kB - 01/12/2024 at 12:45 |
upper_hull_deck.stl3D STL file containing the deck of the boat (upper part of the hull)Standard Tesselated Geometry - 36.90 kB - 01/12/2024 at 12:44 |
mast.stl3D STL file conting the mast.The mast will go on the grand trapdoor (by nesting), and the grand trapdoor will be put on the boat deck Standard Tesselated Geometry - 61.70 kB - 01/12/2024 at 12:40 |
BattleBoatGameCode.inoArduino code of the entire projectino - 3.08 kB - 01/12/2024 at 12:23 |
