Last seances
01/12/2024 at 13:21 • 0 commentsWe pluged the motor two the gear.
We installed the photo resistors.
We finished printing and installing the details of the boat for the decoration.
7-8th sceance
01/12/2024 at 13:20 • 0 commentsWe needed to filed the gear so that it work out well.
We connected the two motors to make a turret. The whole canon was working.
5-6th sceances
01/12/2024 at 13:10 • 0 commentsWe finished coding the laser, the photoresistors and the leds.
We printed the gear and start installing everything on the board.
3-4th seance
01/12/2024 at 13:00 • 0 commentsWe print the boat in 3D.
We learnt to use a button with a cooldown using millis() instead of delay.
At the same time we code the laser and learnt how to calculate the appropriate resistor.
First two sceance on Battle boat game
01/12/2024 at 12:57 • 0 commentsFor the firsts sceances we start thinking about the concept of the game and the design of the boat.
In parallel of modelling the boat, we coded the two stepper motors connect to the joystick.
We tried it on Thinkercad with two potentiometer. Then replace the potentiometer by the joystick.
