Connect XIAO ESP32 C3 with DHT11 via I2C
Connecting a DHT11 sensor and an OLED display to the XIAO ESP32C3 via I2C to monitor humidity and temperature in a DIY smart home device.
This project connects XIAO ESP32 C3 with DHT11 (Temperature and humidity sensor) via the I2C.
Portable Network Graphics (PNG) - 1022.03 kB - 02/15/2024 at 05:43
Preview
Download
  • 1 × XIAO ESP32 C3 The XIAO ESP32 C3 is a development board designed for hobbyists and makers who want to create Internet of Things (IoT) projects. It is based on the ESP32-C3 microcontroller, which is a low-power, Wi-Fi and Bluetooth-enabled chip from Espressif Systems. The XIAO ESP32 C3 board is small and lightweight, making it ideal for portable projects. It also has a built-in USB port, making it easy to program and debug. The XIAO ESP32 C3 board is a great choice for beginners who want to get started with IoT development. It is also a good option for experienced makers who want a powerful and versatile development board for their projects.
  • 1 × DHT11 The DHT11 is a basic, ultra low-cost digital temperature and humidity sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air, and spits out a digital signal on the data pin (no analog input pins needed). Its fairly simple to use.
  • 1 × 0.96 OLED Display A 0.96-inch OLED display is a small, organic light-emitting diode (OLED) display that is commonly used in various electronic devices and IOT projects. .
  • 1 × jumper wires Used to connect the above components.
