HP437B power meter teardown
HP437B power meter examination
Item was tagged "faulty" (without saying what the fault was. I had a look inside.
It wakes up, does a self-test, without complaint.
An instrument built with 1980s era parts, all through hole, no SMDs, or ASICs. You can look at what is inside and see the hardware structure and what is going on.
Controlled by a 6809 processor with 32K ROM and 8K RAM, plus an 8051 microcontroller.
It has a 6840 programmable timer module but no serial I/O, just an IEEE488 peripheral interface.
There is one GAL chip, without the security bits blown.
I have read the GAL and the firmware ROM.
U8rev2-0.out.txt
text/plain - 975.30 kB - 03/09/2024 at 03:03
Download
U8rev2-0.asm.txt
text/plain - 311.97 kB - 03/09/2024 at 03:02
Download
U8rev2-0.info.txt
information guiding the disassembler
plain - 9.53 kB - 03/09/2024 at 19:31
Download
analyse.sh
application/x-shellscript - 367.00 bytes - 03/08/2024 at 01:40
Download
00437.eqn.txt
plain - 2.03 kB - 02/28/2024 at 00:20
Download
View all 15 files
  • ROM disassembling
    Keith03/08/2024 at 01:37 0 comments
    I installed this disassembler:
    https://github.com/Arakula/f9dasm
    and had a first go at disassembling.
    It is a pretty powerful tool.
    Much of the ROM seems to be arrays of words, making me wonder if there if they used some kind of FORTH interpreter to get the code density up.
    I don't have time to reverse engineer FORTH code!
  • Photos
    Keith02/23/2024 at 02:12 0 comments
    Front view:
    Rear view:
    Bottom view, feet;
    Two screws were hidden under the round calibration labels.
    Bottom view, two rear screws hidden under the feet:
    Side view, pull the sticky bits off:
    Complete top board:
    Ooh look, a 68B09E. The 63B40 is a programmable timer module serial I/O and the two 63B21 provide parallel I/O.
    I don't know what the 80C51 microcontroller does. Maybe helps manage the front panel?
    The oscillator is 16 MHz.
    ROM (8k), RAM (8k HN27C64) and the IEEE interface:
    The intel P8291A is the IEEE488 talker/listener interface, the DS75160AN and DS75161AN are the buffers in standard 0.3" wide DIP (unlike the Texas Instruments buffers).
    I don't know what the logic chips below the CPU do.
    The battery is a very healthy 3.45 volts.
    Underneath is the analogue board. The two metal cans shield the RF stuff.
    Close-up views
View all 2 project logs
