Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Motion-sensor equipped Power LED Driver
A compact board containing an AVR microcontroller that controls a power LED driver which can be activated via motion sensor
roger_archibaldroger_archibald
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
547 followers
  • Description
  • Details
  • Files 7
    • View all
  • Components 0
  • Logs 8
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
704
0
547
6
Team (1)
  • roger_archibaldroger_archibald
Join this project's team
ongoing project
Related lists
Projects using OSHpark boards
projects using the purple PCBs
This project was created on 01/18/2017 and last updated 4 years ago.
Description
This board/project is all about a compact board packed with an ATTiny microcontroller driving an LM3405 power LED driver. The Tiny is constantly monitoring an on-board motion sensor and can activate the LED driver when motion is detected.
I initially designed this to be part of an under-cabinet, motion-sensor-activated LED lighting system...While preparing food in the kitchen, the sensor sees your hands moving and keeps the counter lit up. When finishing in the kitchen, just walk away and the lights turn off a few minutes later. No wasted energy and hands-free operation. We've become addicted to this kitchen light, and this circuit could also be put to many other cool uses from security to ambient/decorative lighting.
Power LED's are a lot of fun to play with but they require some sort of drive/regulation. The LM3405 is a great little chip to control power LED's, and this board gives some great control options in a compact package that can be tucked into a tight ar
Files
drilljig3.stl
Standard Tesselated Geometry - 68.15 kB - 03/10/2017 at 02:43
Download
rev3board_drilljig_withletters.stl
Standard Tesselated Geometry - 655.13 kB - 03/10/2017 at 02:42
Download
sliding_endpiece_35mm.stl
Standard Tesselated Geometry - 82.15 kB - 03/10/2017 at 02:40
Download
Assembly Instructions_4foot.pdf
Assembly instructions for 4' LED strips
Adobe Portable Document Format - 33.53 MB - 03/04/2017 at 20:13
Preview
Download
Switch6.sch
Eagle Schematic for this assembly
sch - 765.04 kB - 02/11/2017 at 20:55
See BOM
Download
View all 7 files
Project Logs
Collapse
  • A little Fishy
    roger_archibald • 06/29/2017 at 11:42 • 0 comments
    Here's a shot of a custom strip that I made for a fellow member of the Texas Maker's Guild to aide when he's demonstrating his aquaponics setup. The firmware is written so that it's just alway's on, there's no motion sensor or button installed. 3D-printed end caps double as braces to start it up off the tank a little bit.
  • Kits now available on Tindie!
    roger_archibald • 03/14/2017 at 01:44 • 0 comments
    Strip Kits are now on Tindie!
  • Added STL files for light strip assembly
    roger_archibald • 03/10/2017 at 13:05 • 0 comments
    Attached 3 stl files for the end caps that clean up the ends of the Under-Cabinet light strips and drill jigs for drilling the aluminum bits to build up the assembly.
  • Created first draft of light strip assembly instructions
    roger_archibald • 03/04/2017 at 20:21 • 0 comments
    Uploaded a pdf of assembly instructions to build this board into a motion-activated under-cabinet LED light strip. I'm open to any feedback on how to improve this.
  • Link to firmware on GitHub
    roger_archibald • 02/10/2017 at 03:03 • 0 comments
    https://github.com/rogerarchibald/Channel_Switcher
  • Board Overview
    roger_archibald • 02/08/2017 at 05:42 • 0 comments
  • 2' LED strip assembly video
    roger_archibald • 02/07/2017 at 12:57 • 0 comments
    Instructions for assembling this controller into a 2' motion-activated LED strip.
  • Now on Tindie!
    roger_archibald • 02/07/2017 at 12:52 • 0 comments
    This project is now available on Tindie here: https://www.tindie.com/products/rogera/motion-activated-led-driver/
    Soon to come will be a kit with all required parts to put together an under-cabinet motion-activated power LED strip.
View all 8 project logs
Log In/Sign up to comment
Sign up with Github
OR
This system can realize infrared entrance guard monitoring and uses the active buzzer to finish alarm.
Project Owner Contributor
Anti-theft Alarm System with Arduino
icstationicstation
Motion, sound, and light interactive LED sculpture powered by the Pixelblaze controller
Glow Flow
RogerRoger
I was given a couple of old NEC projectors, both worked, only one had a bulb (and I wasn't going to spend £100)
100w LED projector conversion
ric866ric866
LED desk lighting
deskLight1
matt thurstanmatt thurstan
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "Motion-sensor equipped Power LED Driver", please tell us the reason.
Send message
Remove Member
