Almost Done
04/11/2024 at 23:26 • 0 commentsWe are very close to fully releasing Modufix
Cellular - 4G or 5G?
03/28/2024 at 20:57 • 0 commentsThe question of 4G or 5G has been brought up in design, and i have decided to use a design based on Sixfab's design (https://sixfab.com/product/raspberry-pi-base-hat-3g-4g-lte-minipcie-cards/.)
Unfortunately the design does not support 5G, but i may be able to make a simmer design with 5G.
Pi Zero Support End Of Life
03/24/2024 at 04:12 • 0 commentsUnfortunately I had to cancel plans to be able to use a Pi Zero with Modufix. I had to do this as the limited capabilities the zero has at the moment, with only 512MB of ram it would have been impossible to port android to it. Also getting a display to work with HDMI was also going to be a challenge for a sub $200 display. I know this may be bad for some people who already had a pi zero on hand to start the project, but without it version 6 and onwards will have a much cleaner and better design.
- Shambler
