Modufix - DIY Open source modular phone
Based on Compute Module - 3D Printed open source design
This is a phone design for the next generation, modular design helps against E-waste. the idea is that you can buy a pre built model though me or you can make your own, after a few years you can swap parts out to keep the phone for running longer.
Links:
Files and compatibility: https://docs.google.com/spreadsheets/d/1RRsYXIaR6VpZrMx9XbYSNNYPVBJPBTRpmUzjcQp7AMI/edit?usp=sharing
  • Almost Done
    Shambler.bowler04/11/2024 at 23:26 0 comments
    We are very close to fully releasing Modufix
  • Cellular - 4G or 5G?
    Shambler.bowler03/28/2024 at 20:57 0 comments
    The question of 4G or 5G has been brought up in design, and i have decided to use a design based on Sixfab's design (https://sixfab.com/product/raspberry-pi-base-hat-3g-4g-lte-minipcie-cards/.)
    Unfortunately the design does not support 5G, but i may be able to make a simmer design with 5G.
  • Pi Zero Support End Of Life
    Shambler.bowler03/24/2024 at 04:12 0 comments
    Unfortunately I had to cancel plans to be able to use a Pi Zero with Modufix. I had to do this as the limited capabilities the zero has at the moment, with only 512MB of ram it would have been impossible to port android to it. Also getting a display to work with HDMI was also going to be a challenge for a sub $200 display. I know this may be bad for some people who already had a pi zero on hand to start the project, but without it version 6 and onwards will have a much cleaner and better design.
    - Shambler
View all 3 project logs
Navarre wrote 03/28/2024 at 20:47 point
I have been wanting an open source phone for some time (at least 2009), so this looks very interesting!
antondybikov wrote 03/21/2024 at 14:59 point
VoIP systems often come with built-in analytics tools that provide valuable insights into call data, helping businesses track performance, monitor call volumes https://onecloudnetworks.com/secure-communications/, and improve customer service.
