Team Besteam'z Project
lght saber
This is a lightsaber. It is a blade version. We have decided to make a saber with a light strip in the back to light it up. It has a pommel and a handle that is shapely. It is super cool.
https://www.youtube.com/watch?v=bOaxN0gA8hU
MATERIALS        PRICE
  • something to cut acrylic with (laser, jigsaw, ect)                : NA
  • 3D printer        : NA
  • PLA 3D printing filament (Color of your Choosing)           : $24.99
  • Neopixel Strips        : $12.99
  • Xiao RP2040        : $5.40
  • On/Off Click Switch                                                            : $10.90
  • Momentary Push Button                                                    : $8.99
  • 1/4 Inch Translucent Acrylic                                               : $14.99
  • 18650 Battery        : $3.99
  • LED Strip Light Connectors                                              : $9.99
  • Battery Charger Board/Battery Holder                            : $9.99
  • WAGO 221-415        : $9.49
  • Wires        : $9.99
  • USB C Female Connector                                                : $8.99
  • USB C Cable        : $9.99
  • Double Sided Tape                                                          : $4.99
  • M4 Set Screw                                                       ...
Portable Network Graphics (PNG) - 150.31 kB - 03/26/2024 at 15:52
Preview
main.py
py - 1.48 kB - 03/26/2024 at 15:39
Download
neopixel.py
py - 7.77 kB - 03/26/2024 at 15:39
Download
JPEG Image - 5.46 MB - 03/25/2024 at 16:23
Preview
JPEG Image - 4.65 MB - 03/25/2024 at 16:23
Preview
View all 19 files
  • 1
    Gather Materials
    1. Purchase them.
    2. Wait for shipment.
    3. Open them.
  • 2
    Modeling
    1. First create the handle
      1. Make sure it is wide enough in the center so that the electronics sit inside
      2. Make sure the hole where the handle fits in is thick enough for the thickness of the glass but not so loose to have it fall out.
      3. Make sure to also account for the backing that is larger and at the end of the blade that must also fit into the handle
      4. To make the holes create an offset plane and create a hole to the circumference of the buttons
      5. Same with the charging port
      6. Make the inside threads
    2. Create the pommel
      1. Create offset planes for the details
      2. Create the inside threads
    3.  Create the backing
      1. Create the backing so there is room for neo pixels
        1. Leave a little wiggle room
      2. Have it go in to then clamp on the blade
      3. Create holes for setting screws
  • 3
    Printing
    Open the software for the 3D printer you are using
    1. Import the downloaded stl file
      1. To download go into fusion and click export and export as an stl
    2.  Change the color, add support, select the right plate
    3. Slice all files
    4. Download to a usb
    5. Print the pieces one at a time
View all 6 instructions
Tristan wrote 03/25/2024 at 15:31 point
I know
Elizabeth wrote 03/25/2024 at 15:54 point
shut up
Tristan wrote 03/26/2024 at 15:36 point
your so mean :(
Elizabeth wrote 03/20/2024 at 15:34 point
Guys this is so cool
