Ongoing boards!
11/06/2024 at 19:25 • 0 commentsI've also been recently working on some more work..
- A pHAT to get a fast ADC running
- A FT600Q board, where I try connecting a FT600 directly to a 100Msps ADC
- An SDR board, based on the MSI001 / MSI2500 combo
Now seems to work!
04/10/2024 at 21:02 • 0 commentsAfter some soldering (thanks OSHPark, again ;) )... with some 2-layer and 4-layer boards (you know which is which, you recognize the "after dark" style)..
The three boards once assembled look like this
Example of acquisitions
This is pretty much on part with the un0rick or the lit3rick boards.. so .. success !!
kelu124
