BlackberryPi Handheld
Handheld Gameboy style full Linux computer, like Clockwork Pi, but with a Blackberry keyboard/mouse, and nothing proprietary!
So I love handhelds, and I love Cyberpunk type gadgets. And I love Linux. I really like the Clockwork Pi handheld, but the price, low availability and seemingly finicky nature led me to make my own. Follow along as I attempt to build a handheld PC that doesn't suck, runs a full desktop, and runs on a Raspberry Pi - so it's easy to run any Pi compatible OS without getting too in the weeds.
Download the STL's here to print your own! - https://makerworld.com/en/models/1136187
Purchase the STEP file here if you want to customise it! - https://www.patreon.com/TaylorHay/shop/blackberry-pi-cad-file-step-248650
  • 1 × BB Q10 Keyboard https://www.tindie.com/products/zitaotech/bbq10-bleusb-keyboard/
  • 1 × HyperPixel 4.0 Square (Touch) https://shop.pimoroni.com/products/hyperpixel-4-square?variant=30138251444307
  • 1 × Raspberry Pi (I'm using Pi 4 8gb, but use whatever!)
  • 1 × 10,000mah lipo (harvested from a $15aud power bank)
  • I'll call it good.
    Taylor Hay02/22/2025 at 09:55 0 comments
    She's all done!
    Well that's a wrap - I've finally made my build video for this project, check it out below! There are some improvements to be made - I hope some people take this on and build their own, improving on my design!
    STL's available on Makerworld - https://makerworld.com/en/models/1136187
    STEP file available on Patreon (free for Patreons, otherwise a few $ one off) - https://www.patreon.com/TaylorHay/shop/blackberry-pi-cad-file-step-248650
  • It’s alive!
    Taylor Hay05/05/2024 at 10:13 0 comments
    this morning started with soldering the usb cable to the Pi, and what a headache that was! Turns out the usb cable I was using had data lines in it, but they weren’t terminated at the usbc and… cheap nasty cable. So I had to do it all again. But I got the keyboard talking to the Pi, bypassing the physical usb port.
    Next was spot welding a little 1s3p 18650 pack, and replacing the big lipo pouch that the power bank originally had. These are 3000mah cells, so I have 9000mah total - pretty nice!
    I once again had to remove the usb ports on the power bank board, and solder a chopped usbc cable on, but I like that the back can be removed, unplugged, and the pi can be powered externally (I already had to use this feature to hook up an external monitor to get Kali Linux working on the Pimaroni screen)
    The board + batteries JUST fit! And it’s nice to have USBC fast charging.
    Annoyingly this board cuts the output when I’m charging it, so it’s unable to boot the pi when plugged into USBC - which is not ideal. So I might revisit the charging board.
    I do however really like the battery percentage display, that fits though the case. It’s a bit too bright, but a bit of Smokey acrylic might help that in the future.
    It’s running Kali Linux on a 32gb card at the moment - and does exactly what I had in mind! So far battery life seems to be excellent.
    I’ll make some qol updates and probably reprint the case in a nicer material next!
    Edit: If anyone is replicating this project, getting the Hyperpixel to work with Kali requires another step - I hooked it up to an HDMI screen and ran the following command
    curl -sSL get.pimoroni.com/hyperpixel4-legacy | bash
     And in the config chose my Pi type and Screen (square vs rectange)
    rebooted and it worked! This link might have more info if that doesnt work for you.
  • Blackberry Pi
    Taylor Hay05/01/2024 at 12:15 0 comments
    My keyboard arrived yesterday! I wasted no time pulling it apart, making a few changes to my case model, and printing a new revision.
    The Pi+Hyperpixel screen assembly fits great. It drops in from the front and secures from the back, and then a bezel (not pictured) will attach to the front.
    The keyboard is great - and the mouse works better than I expected! Very easy to get around a full desktop environment - Plasma feels great, even at 720x720!
    At the moment, the keyboard is plugged into a USB Port on the outside, but my plan is to directly solder the USB cable to the pins, and print a little "USB blank" to close up the port that will be used for the keyboard/mouse.
    So far it's on track to need no software - meaning you can install anything you want on the Pi, as long as the Hyperpixel is supported. No software needed at all - it's all plug and play.
    Next step is the front bezel, back cover, battery, wiring and power button.
    Stay tuned!
  • And so it begins...​
    Taylor Hay04/12/2024 at 06:43 0 comments
    This has actually been a long time coming! I built a CinePi cinema camera last year, and although it's great - I dont actually need / enjoy working with cinema footage... so I decided to use the incredible Hyperpixel screen, and the best Pi in my collection (Pi 4, 8gb) to make a handheld Linux PC. Excellent for portable Pen Testing with Kali, or doing anything! Mainly though, I just think it's cool.
    The keyboard has always been what's held me back though. I was going to design a PCB with a heap of tactile buttons, kinda like in the Armachat devices - but they dont look nice to type on, and it still leaves the question of a mouse open.
    When I saw this Blackberry breakout keyboard with a mouse built in - I knew it was destiny! I ordered one, and grabbed the STL files from ZitaoTech's Github, reverse engineered them into a solid body (best Fusion 360 feature ever...) and then designed a case that holds the Pi and the Hyperpixel screen.
    I should be able to transfer the keyboard into my new frontplate, and use the original backplate. Hoping that I can use it as a USB device without the battery.
    A chopped USB cable soldered directly to the USB pins on the pi will take care of connectivity - and that's my mouse and keyboard sorted!
    https://www.tindie.com/products/zitaotech/blackberry-q10-bleusb-keyboard/
    The case is still very much a work in progress, but a large 10,000mah pouch lipo will be integrated into the back part of the case.
    It will be a bit thick - but I love the idea of lots of battery life... I'm using the power bank's button to power it on an off, and I'll reroute the power bank battery % display somewhere to keep an eye on that. I could possibly integrate it with software, but that seems hard. And a physical battery display visible from the outside (similar to early MacBook Pro's that had that little button) will be cooooool!
    The bottom case of the keyboard is the original mesh here, while the top part is integrated into the rest of the case
    Once the case is finalised, I'll aim to machine parts from aluminium and print parts via HP Multijet Fusion from PCBWay (similar to my Cyberpunk Baofeng Radio project)
    Just waiting for the Keyboard to arrive, and I'll post an update when it's more assembled!
View all 4 project logs
John585 wrote 02/25/2025 at 22:57 point
The seller of the keyboard currently says they are 'talking a break', which is understandable for small time component producers.  Option 1 is to wait for them to make more.  Option 2 is to find an alternative keyboard/mouse that will work (without over-complicating things).  Any ideas for an alternative kb/mouse module for Option 2?
Taylor Hay wrote 02/25/2025 at 23:35 point
I really liked Abe's solution in this video - https://www.youtube.com/watch?v=rnwPmoWMGqk
I think my next project will be a BB keyboard breakout...
tienquangbmt wrote 12/04/2024 at 04:30 point
Good work! It doesn't have a cooling fan, is there anything wrong with it?
Pattycakes98-code wrote 09/20/2024 at 19:24 point
Just completed this project. Added a few modifications to the STL files to accommodate the 5v3a 21700 power boost module and a power switch. Wanted to say this project is awesome man, exactly the kind of thing I've been looking to build for quite some time. I'm currently running Parrot OS instead of Kali but it works just as well.
Lenard wrote 05/15/2024 at 00:19 point
Hi, is it possible to get the design file!! I was looking one of this so long,
Taylor Hay wrote 05/15/2024 at 00:40 point
No worries! I just uploaded STL's on here! 👍🏼
Lenard wrote 05/15/2024 at 06:28 point
Thanks alot. I have RPI 5, is that fit for RPI 5?
tienquangbmt wrote 12/04/2024 at 04:37 point
Is it possible to make STL for the case available? This project is PERFECT. You can make it ready with all screen, keyboard, power but no need for raspberry and I will order it from you, thank you.
Biểu tượng Cộng đồng đã xác minh
[deleted]
Man, thanks so much for the kind words!
QT-1 wrote 05/07/2024 at 14:46 point
Is it possible at all to make the STL for the case available? This project looks PERFECT. I was very interested in the ClockworkPi handheld, but have the same concerns. This project is exactly the kind of device I've been trying to find/build.
Taylor Hay wrote 05/15/2024 at 00:39 point
Aniki wrote 05/06/2024 at 12:48 point
Any chance we can get the STL file you used? I might do something a bit bigger/different and it would really save a ton of time not having to remake the keyboard part! Thanks!!!
Wait NM I just found the originals in ZitaoTech's repo!!
Good work! He's been super helpful. I just uploaded STL's on here as well if needed! 👍🏼
quintinscherrer wrote 04/11/2024 at 16:03 point
could there be a cheaper keyboard alterntive
Taylor Hay wrote 04/12/2024 at 06:16 point
Absolutely! Blackberry Keyboards are $1usd on Aliexpress, you just need to roll the board and key matrix PCB, and figure out a trackball mouse. I reckon the $40 or so for that all being done is a bargain though!
