blink(1) sconces
Add-on diffusers for blink(1) mk2 USB RGB LED
The blink(1) USB LED has an easily removable case. The design is open source and I've always wanted to have extra add-on diffusers for wall-mount or cubicle mounting. Something that really showcases how bright the two WS2812 / Neopixel LEDs in blink(1) are.
These are my experiments in making these diffusers, by way of learning Fusion 360.
There are two methods I can see for attaching add-on diffusers to blink(1):
* mount directly to PCBA
* mount to metal frame (that carries PCBA)
I was initially designing for the former, but I think it will be structurally stronger (and safer for the PCBA) if I design for the latter.
blink1SconceLoopFrame.stl
Standard Tesselated Geometry - 93.34 kB - 02/13/2017 at 06:20
Download
blink1SconceFrameArch2.stl
Standard Tesselated Geometry - 89.44 kB - 02/13/2017 at 06:20
Download
blink1SconceFrameArch1.stl
Standard Tesselated Geometry - 52.33 kB - 02/12/2017 at 21:28
Download
blink1SconcePCBArch2c.stl
Standard Tesselated Geometry - 128.01 kB - 02/12/2017 at 21:22
Download
blink1SconcePCBArch1a.stl
Standard Tesselated Geometry - 78.11 kB - 02/12/2017 at 21:22
Download
View all 8 files
  • 1 × blink(1) mk2 blink(1) USB RGB LED
  • Is it a spaceship or a blink(1)?
    todbot02/13/2017 at 06:22 0 comments
    I think the metal frame-based mounting is working well.
    Also this...
  • Metal frame-mounted sconces: better
    todbot02/12/2017 at 21:28 0 comments
    I think frame-mounted sconces work better.
    The first attempt (uploaded as "blink1SconceFrameArch1.stl") is much more stable than the PCB-based mounts.
    Problems with this first attempt though:
    * mounting arms block some of the side-emitting light
    * mounting grippers are 2mm too wide on each side
    Thus fixes to try:
    * move mounting arms forward towards USB jack: gives more space for light
    * eliminate 2mm space on grippers
  • PCBA-attached sconces
    todbot02/12/2017 at 21:24 0 comments
    I've uploaded several attempts at PCBA-mounted sconces. They work... sorta.
    Things I like about some of the designs, even with the bad mounting technique:
    * the circular arc diffuser is minimally classic
    * two of the designs have inserts for a message to help define what the blink(1) is for (see the "NO NO NO") in one of the photos
View all 3 project logs
  • 1
    Step 1
    These designs assume a 3d printer with translucent material. Natural PLA or natural ABS will both work.
    Printing parameters:
    • 0.2mm layer height
    • 100% infill
    • supports requires
    • raft optional
View all instructions
