The power supply and the sensor input portion schematic:
Connectors for LCD and ISP
The controller portion, ATMEGA8
The source code is provided below in the READ MORE LINK, otherwise the project page would have gone a bit too long, for ALL the files related to the project, use this link: http://zaidpirwani.com/1246/tachtastic-avr-tachometer-2/
EjaadTech
On top is the ISP connector for programming, on the left are the extra pins left, the sensors input were put with a 3.5mm audio jack female connector and the 2 ICs, the Opamp and the ATMEGA8 were concealed beneath the LCD.
the first simplest sensor, a pass-through...
ilo
Arduino KIT
BlueFlower
Matt
