DIGI LOCKER
There is a mobile application in which we add Driving licenses and vehicle registration no. & PUC certificate election card passport no.
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
for accessing the information there will be bar code or qr code by which everyone is able to access the documents available on the mobile application. by just login with registered email id any where or by login on any other device the digi-wallet will be there in mobile application for any kind of fine. with this,no one has to carry the paper documents,because every documents is available in a mobile application as there are only certified documents in the mobile application,this will reduce the duplication of documents and helps in corruption free world.This will reduce the wastage of time and on single click people can send there documents to any government official or any where people required the user can use registered email id anywhere or by login on any other device for documents this will reduce the use of paper,which is helpful for environment..
