Water Coagulator / Electrolysis Kits & Curriculum
Advancing DIY Water Purification
with Students & Citizen Scientists Around the Globe.
We're evolving coagulator/electrolysis kits that can be used in the classroom for chemistry curriculum as well as coding and water purification projects. We collaborate with students, educators, & citizen scientists to learn about the process along with us and help improve the curriculum and the kit capability by adding sensors, advancing the design, and submitting video entries for our Make Water YouTube series.
Thank you for checking out our project! We hope we can collaborate with you and your community to test these kits on a water problem you might be facing or connect you with students tackling existing issues.
We have an existing prototype with parts listed but we are moving towards a new design that would require less tedious wiring and possibly cost less.
Goals
  • Study & develop the electrocoagulation process collaboratively using DIY Open Source methods.
  • Activate and engage students and citizen scientists to participate.
  • Evolve the coagulator kits to simplify use and add data logging & sharing capabilities.
  • Share our progress through video entries.
Coagulator Ludus-Single.ino
Arduino Uno sketch for a single coagulator with sparkfun ludus shield.
ino - 844.00 bytes - 04/25/2017 at 17:35
Download
Coagulator Ludus-Dual.ino
Arduino Uno sketch for dual coagulators with sparkfun ludus shield.
ino - 1.22 kB - 04/25/2017 at 16:38
Download
Coagulator Arduino Case-Lid.stl
3D Print STL file for Arduino Uno & Ludus Shield Case - Lid - Credit: Steam Central Makerspace
Standard Tesselated Geometry - 303.50 kB - 04/25/2017 at 17:33
Download
Coagulator Arduino Case-Base.stl
3D Print STL file for Arduino Uno & Ludus Shield Case - Base - Credit: Steam Central Makerspace
Standard Tesselated Geometry - 1.59 MB - 04/25/2017 at 17:33
Download
Coagulator 16oz Full Lid.stl
3D Print STL file for full size screw on lid for 16 oz mason jars.
Standard Tesselated Geometry - 1.06 MB - 04/25/2017 at 16:38
Download
Coagulator 16oz Flat Lid.stl
3D Print STL file for 16 oz mason jar flat lid. Requires screw on outer ring that comes with mason jar. - Credit: Harmony High School
Standard Tesselated Geometry - 322.45 kB - 04/26/2017 at 13:03
Download
View all 6 files
View all 3 project logs
  • 1
    We are changing our prototypes to a new build and will add instructions and update components for that build soon.
View all instructions
Ryan Beltrán wrote 2 days ago point
Updated the files for the new coagulator kits using ludus boards and arduinio UNOs. Still need the 3D printed case base file.
