Patch_1.0.0.v
Patch 1.0.0
What has been added-
1. JIZ instruction
Jump to referred address if Register Location has
zero as content.
opcode- 1111
Intruction- 1111_(4bit Register)_8bit address
v - 14.01 kB - 04/02/2017 at 21:44
Download
Program Counter.v
Program Counter which counts and iterates over addresses of instructions
v - 285.00 bytes - 04/01/2017 at 18:56
Download
Risc Top Module.v
This describes the topmost module which connects datapath and control unit
v - 473.00 bytes - 04/01/2017 at 18:26
Download
All the connections between modules.
Note- It shows datapath connection and not control unit
JPEG Image - 127.34 kB - 04/01/2017 at 18:26
Preview
Download
SignExtend.v
It used to extend 4 bits from instruction [3:0] to 8 bits for jump or branch offset and for ALU
v - 147.00 bytes - 04/01/2017 at 18:26
Download
Multiplexers.v
A total of 5 multiplexers have been used here
v - 500.00 bytes - 04/01/2017 at 18:26
Download
RegisterFile.v
Register file. R0 always contains zero.
A total of 15 general purpose registers have been used. You may increase the number of registers by changing array dimention and vector
v - 1.21 kB - 04/01/2017 at 18:26
Download
Datapath.v
Datapath module involves connection between all the modules
v - 1.31 kB - 04/01/2017 at 18:26
Download
HellFixture.v
Test bench providing clock and reset.
NOTE reset might crash the processor at somepoint of instruction. Not sure.
v - 950.00 bytes - 04/01/2017 at 18:26
Download
v - 6.35 kB - 04/01/2017 at 18:26
Download
ALU.v.v
Module for arithmetic and offset calculations
v - 1.72 kB - 04/01/2017 at 18:26
Download
updated R--I--JMP--BEQ.v
A sum of all codes
v - 12.81 kB - 04/01/2017 at 18:26
Download
