Remote Pet Feeder
Bubbles won't be forgotten, even if you forget!
You can either feed your pet remotely by pressing the button in Cloud Control (on your phone or computer) or you can set up an automated feeding schedule through IFTTT (If this then that). IFTTT is a service that lets you connect to different web apps through simple conditional statements.
Any time the feeder receives a signal through the cloudBit, the servo is activated. In our case, we attached a fish food container with a small hole drilled in its side to the servo. When the servo turns, a few pellets drop out of the container and into the bowl.
You can activate the servo remotely in a couple different ways. You can either use the littleBits button in Cloud Control to send a single pulse to the cloudBit, activating the servo. Or, you could use an IFTTT channel, like Date & Time to automate the feeding at times you set.
  • 1 × cloudBit
  • 1 × servoBit
  • 1 × usb powerBit
  • 1 × 3/8" wood dowel
  • 4 × Adhesive Shoes
View all 13 components
  • 1
    Step 1
    1. Begin by making the stand for the remote pet feeder. Laser cut all the pieces using our attached cut template [remote pet feeder laser cut]
    2. 2.  Using acrylic glue, glue the two layers of the base together (¼ thickness clear acrylic). The maximum thickness that our laser cutter can cut is ¼”, so we doubled up the layers here to make a sturdier base.
    3. 3.  Next, glue the base and two side pieces together.
    4. 4.  Cut a ⅜” wood dowel to connect the two sides at the top, providing support for the feeder. The length of the wood dowel you cut should be 4 inch. After you cut the dowel to size, sand the two ends to make them clean and smooth looking.
    5. 5.  Assemble the top shelf. Secure the shelf arms to the inside of the stand. Use nuts and bolts to do this.
    6. 6.  Secure the servo to the servo holder. We used small nylon nuts and bolts.Then place the servo holder into the slots on the shelf arms.
    7. 7.  Build the circuit.  See the circuit diagram in the image above. Set up your cloudBit if you haven’t already. You can find information about how to do this here: littlebits.cc/cloudstart.
    8. 8.  Stick the circuit to the stand. We used littleBits Adhesive Shoes to hold our circuit in place.
    9. 9.  Make the fish food container. Drill a small hole in the side of the round tin. This is where the food will fall out when the servo turns. Glue or stick the tin to the servo arm, and then place the servo arm onto the servo (you may need to remove the arm that is already on there). Note: you may need to rotate the position of the servo arm so that food falls out how how you like.
    10. 10.  Now you can feed your dear fish remotely! You can activate the feeder in a couple different ways. You can either use the littleBits button in Cloud Control to send a single pulse to the cloudBit, activating the servo. Or, you could use an IFTTT channel, like Date & Time to automate the feeding at times you set.
View all instructions
derrybiken wrote 05/06/2024 at 15:30 point
Hello!
Feeding pets remotely is really convenient! I recently came across an article about why the demand for technology solutions for pets is growing and it piqued my interest (https://www.cogniteq.com/blog/why-demand-pet-tech-solutions-rise). I decided to try this idea in action and turned to Cogniteq to develop a similar application.
And, you know, I can’t help but share my experience! Working on this project has been an amazing journey. With the help of the developed application, I can control the feeding of my pets from anywhere in the world, which brings me great convenience and peace of mind.
If you are also thinking about this solution for your pets, I highly recommend contacting Cogniteq. They are professionals in their field and will help turn your idea into reality.
Good luck to you and your pets will always be in good hands!
zuul wrote 07/24/2014 at 18:47 point
nice, there used to be an irc controlled fish feeder on fmcg
this reminds me of that
