• Image Printing Working
    Toby Jackson04/16/2017 at 11:43 0 comments
    After some trial and error... and aboutl 30 feet of print failures, I've been able to incorporate the escpos-image library so that I'm able to print images embedded into messages.
    Had to make some modifications to the library to support resizing, rotation and formatting but initial results are looking great.
    At this point, Tilly is able to;
    • Print simple text messages
    • Print multi-media messages
      • GIF's take the first frame
      • JPG/PNG are printed properly
      • Resizes to 360px wide (Up/Down as required)
    Can't yet print emoji, and will probably be a long-time before thats possible as all text would need to be 'rendered' onto a bitmap rather than as ascii text over serial.
    Attachment's can't be printed yet either as Slack puts them in a strange place (Not on a channel technically...) so more work required there.
  • The Initial Implementation
    Toby Jackson04/14/2017 at 20:09 0 comments
    So in a rare case of completionism, I've managed to build a viable 'finished' article of a printer connected to Slack.
    Its rough around the edges - the power supply is pretty rubbish (USB to the RPi and a separate wall-wart for the printer itself), the external wiring is a bit messy (three cables rather than two) and the code is a little unruly but it works.
    Next things to solve;
    1. Power supply - Can I run the Pi and Printer from one source?
    2. Images/Multi-Media - How can I print image embeds or avatars as part of the output
