Hackaday.io Hackaday.io
Sign up Log in
Enhanced IOT Light Switch
Particle Photon + PIR Motion Sensor + Temperature Sensor = Enhanced IOT Light Switch
eric-moyerEric Moyer
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
552 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
  • The 2017 Hackaday Prize
View Gallery
851
0
552
8
Team (1)
  • eric-moyerEric Moyer
Join this project's team
  • Enhanced IOT Light Switch Project Code
  • Sparkfun TLS2561 Luminosity Sensor Exampl
  • Sparkfun TLS2561 Luminosity Sensor Librar
  • Adafruit TLS2561 Luminosity Sensor Librar
  • Adafruit Sensor Library (need with the ab
hardware
ongoing project
2017HackadayPrize Particle Photon iot motion light switch
Related lists
2017 THP: Digi-Key Parts
Hackaday Prize Entries using Digi-Key parts
This project is submitted for
  • Design your concept
  • Best Product
This project was created on 04/19/2017 and last updated 9 years ago.
Description
You have at least one light switch in every room of your house however we have only been using these fixtures to turn on/off the lights. Even &quot;smart&quot; light switches haven&apos;t expanded the role your light switch can have in the overall function of your home. This project will expand the functionality of you light switch and make it truly &quot;smart&quot;. First, lights switches have already been ideally placed in your home since they provide a key function (turn on/off the light(s)) and thus are typicaly at the entrance to every room and all high traffic areas. They also provide a power source for any additional electronics that need to be added to the system so you don&apos;t have to worry about a perfectly placed outlet. The heart of this new system will be a Particle Photon development board which provides instant cloud interface using <a href="http://Particle.io" target="_blank">Particle.io</a> or IFTTT.
Files
Enhanced IOT Light Switch.pdf
Information flow for each component of the enhanced lights switch.
Adobe Portable Document Format - 1.46 MB - 04/19/2017 at 23:36
Preview
Project Logs
Collapse
  • 4/19/2017: Additional Project Information
    Eric Moyer • 04/19/2017 at 23:50 • 0 comments
    I posted a .pdf file that covers how I expect information to flow between all the components of the project.
    Here is an example:
    Thank you again to everyone who is following this project. Don't forget to "like" it.
  • 4/19/2017: Project Kick Off
    Eric Moyer • 04/19/2017 at 08:24 • 0 comments
    Thank you for taking the time to look at my project. Please don't forget to "like" the project since there is still a few $$ of funding available.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
One touch cozy mood makes the ambience more comfortable and according to users mood after a long tiring day at work.
Project Owner Contributor
One touch cozy mood
nishant-kshirsagarNishant Kshirsagar
Hackaday Prize 2019
PID control system of a light meter that measures and regulates the lighting of a lamp.
PID Light Meter Controller
guillermo-perez-guillenGuillermo Perez Guillen
A custom PCB that uses a magnetic reed switch to control a lightbulb
Door Sensor Controlled Light
cornelius-robinsonCornelius Robinson
The 2018 Hackaday Prize
This project combines traditional long exposure light painting with LEDs controlled from inside a virtual reality painting application
Light Painting with VR
fhernandfhernand
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Enhanced IOT Light Switch", please tell us the reason.
Send message
Remove Member
