LED Flashlight V2
I read a lot of people using this battery http://www.ebay.com.au/itm/111196510869?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 to run their LED. DONT USE IT. This battery is not for operating the LED. Its a normaly mobilephone battery ( existing of 9 small batteries) The energie the LED needs to run, is not high eneough (discharge energie). When LED takes to much Energie, the protective circuit release and battery cant used anymore. So please use LiPo battery. Every Cell (6 Cell) of the battery has to charge seperate (by using the balancer connector) So you need a spezial Charger http://www.hobbyking.com/hobbyking/store/__216__408__Chargers_Accessories-Battery_Chargers.html What i used to upgrade is a battery controll (cells should not discharged under 2,9 V DC) Contact me if you have questions
Led
Led cooling
Led driver
LiPo battery
LED reflector lense
Aluminium case
Poti to adjust Brightnes
  • 1 × 100W LED
  • 1 × Heatsink Electronic Components / Misc. Electronic Componentshttp://www.ebay.de/itm/10-100W-Watt-LED-Chip-wei-white-DIY-Fluter-SMD-Flutlicht-floodlight-Aquarium-/111129828312
  • 1 × !!! LiPo battery 6S1P 25C 22,2 V (read user manuals, caus of charging) !!! http://www.hobbyking.com/hobbyking/store/__9176__Turnigy_5000mAh_6S_20C_Lipo_Pack.html
  • 1 × Alu Case
  • 1 × Reflector Lense http://www.ebay.de/itm/Reflektor-Optik-Bausatz-fr-20-W-100-W-Watt-LED-Fluter-Flutlicht-Glaslinse-/161222220827
View all 7 components
  • Focusable Lens
    Norman09/30/2014 at 16:21 1 comment
    Added a fucusable Lens and low noise Fan
  • Fan and batterycontroll
    Norman07/31/2014 at 06:10 0 comments
    Next update will be a ultra low noise fan (19 dB or less) and batterycontroll. The batterycontroll is relevant to stepup converter. that means the electric circuit of the batt.controll will be added to the el.circuit of the step up converter.
View all 2 project logs
Ryan Shill wrote 04/20/2015 at 15:20 point
Where did you source the aluminum case?
Norman wrote 04/20/2015 at 20:12 point
www.conrad.de
or just search around your city, if any company is processing metal. Just ask them
The Lightning Stalkr wrote 04/18/2015 at 01:31 point
Control
