GPX Converter.rarTool to convert gCode to Makerbot binary format. Needs proper configuration in param.iniDISCLAIMER: I have only tested this on my Malyan M180 and have no idea if it works with Makerbot at all. RAR Archive - 134.99 kB - 12/12/2017 at 03:40 |
X-Axis.IGSIGS file for 3D printed part so that you can modify it to your desire.Initial Graphics Exchange Specification (IGES) - 2.82 MB - 12/12/2017 at 03:37 |
Z-Axis UpperRodHolder.IGSIGS file for 3D printed part so that you can modify it to your desire.Initial Graphics Exchange Specification (IGES) - 2.24 MB - 12/12/2017 at 03:37 |
Z-Axis RunCat.IGSIGS file for 3D printed part so that you can modify it to your desire.Initial Graphics Exchange Specification (IGES) - 1.66 MB - 12/12/2017 at 03:37 |
NuggetMill5 - step.rarComplete NuggetMill5 as a step file.RAR Archive - 1.51 MB - 07/14/2017 at 01:43 |
pcb-gcode-3.6.2.4.zipThis is a patch for pcb-gcode to add the possibility to mill outlines in a defined number of slices and not just in one go to max depth.Please also override the settings folder. x-zip-compressed - 28.46 kB - 06/22/2017 at 03:02 |
NuggetMill5 Printable Parts.rarThe three printable files for the different axisRAR Archive - 374.46 kB - 06/22/2017 at 02:44 |
Enclosure DXF files.zipAll updated DXF files that I used to build the millx-zip-compressed - 81.77 kB - 06/22/2017 at 02:44 |
