Hackaday.io Hackaday.io
Sign up Log in
Resha
A compact portable 3D printer with folding bed and removable toolheads
mo-badrMo Badr
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
30 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
435
1
30
4
Team (1)
  • mo-badrMo Badr
Join this project's team
MISC
ongoing project
3d printer
This project was created on 06/30/2017 and last updated 9 years ago.
Description
I have been working on this idea for a while: a compact portable 3D printer with folding print-bed and quick-detachable print-heads. The aim is to have a portable 3D printer that I can carry around, much like the Ultimaker 2 Go, but small enough to fit in a laptop backpack or a messenger bag. The design I currently have takes about 25x22.5x5.5cm when the bed and spool holder are folded and the print-head removed (the Ultimaker 2 Go is 28x28.7x25.5cm without Bowden tube and spool). The print-head and power supply can be stored inside the printer, only the filament spool will need additional space (for now!). The print volume is 15x20x17cm, although this requires a slightly more complex mechanism for the y-axis, without it the print volume would be 15x15x17cm. The layer resolution is about 250 to 100 microns. I also have space to add a 12 cell battery, which would theoretically give about two to three hours of printing when using PLA.
Project Logs
Collapse
  • Questionnaire
    Mo Badr • 06/30/2017 at 17:50 • 0 comments
    I would appreciate if you answer the linked questionnaire to let me know if you think this printer is worth buying, at what price, and what features are important?
    https://goo.gl/forms/TRMkjYSkRQtBrpFF3
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
kelvinA wrote 03/10/2022 at 21:19 • point
This project still ongoing?
The 2018 Hackaday Prize
The Automatic Infinite 3D Printer (i3D) gives anyone the power of a factory.
Project Owner Contributor
swaleh-owaisSwaleh Owais
Mostly 3D printed Office printer with a build area the size of an A3 sheet sporting a Diamond 3-colour hotend
(Office 3D Printer) P_3D mk. 1
reniermRenierM
Cantilevered heavyweight
3D Printer - T8 (2018)
chip-barkChip Bark
Supplyframe DesignLab: 2023 Hackada…
This how-to will show how to fit a longer bed on any flashable 3D-printer. We use the long bed ourselves to print windturbine blades.
XL Long bed 3D-printer conversion
fromwastetowindFromWasteToWind
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Resha", please tell us the reason.
Send message
Remove Member
