YGREC8_20231214.tbz
VHDL assembler works
x-bzip-compressed-tar - 205.14 kB - 12/14/2023 at 05:52
Download
YGREC8_20231012.tbz
The new wave of manuals. No source code yet.
x-bzip-compressed-tar - 141.32 kB - 10/12/2023 at 05:52
Download
YGREC8_VHDL.20211120-2.tgz
x-compressed-tar - 372.71 kB - 11/20/2021 at 14:46
Download
YGREC8_VHDL.20211120.tgz
x-compressed-tar - 372.09 kB - 11/20/2021 at 08:56
Download
YGREC8_VHDL.20211118.tgz
assembler refactored, supports DW and re-assembly
x-compressed-tar - 360.31 kB - 11/18/2021 at 17:29
Download
YGREC8_VHDL.20211114.tgz
ALU8 still bork and assembler is incomplete
x-compressed-tar - 359.56 kB - 11/14/2021 at 08:08
Download
YGREC8_VHDL.20211112.tgz
a better assembler starts to work.
x-compressed-tar - 358.68 kB - 11/12/2021 at 06:18
Download
dictionary.vhdl
a dynamic lookup table for the assembler's symbols
x-vhdl - 5.47 kB - 11/08/2021 at 11:21
Download
YGREC8_VHDL.20200825.tgz
some syntax highlighting, new SR FF macros
x-compressed-tar - 351.15 kB - 08/25/2020 at 04:42
Download
YGREC8_VHDL.20200821.tgz
TAP's Selector unit OK
x-compressed-tar - 349.16 kB - 08/22/2020 at 00:52
Download
YGREC8_VHDL.20200815.tgz
TAP bit scrambling order is working again
application/x-compressed-tar - 301.32 kB - 08/16/2020 at 01:53
Download
YGREC8_VHDL.20200814.tgz
Back to Gray6s...
x-compressed-tar - 297.88 kB - 08/15/2020 at 04:45
Download
YGREC8_VHDL.20200813.tgz
Gray7 OK !
x-compressed-tar - 278.49 kB - 08/13/2020 at 03:24
Download
YGREC8_VHDL.20200812.tgz
MUX64 & Gray7s behav.
x-compressed-tar - 278.29 kB - 08/12/2020 at 15:24
Download
YGREC8_VHDL.20200811.tgz
TAP reboot, "SYNTHESIS OK" on some files
x-compressed-tar - 259.30 kB - 08/11/2020 at 06:26
Download
YGREC8_VHDL.20200801.tgz
TAP/Slice in the works...
x-compressed-tar - 358.84 kB - 08/02/2020 at 02:00
Download
YGREC8_VHDL.20200730.tgz
Instruction debug slice added.
x-compressed-tar - 334.00 kB - 07/30/2020 at 21:30
Download
YGREC8_VHDL.20200728.tgz
The selector works. TAP's core is almost done :-)
x-compressed-tar - 320.59 kB - 07/28/2020 at 01:57
Download
YGREC8_VHDL.20200727.tgz
TAP/Counter added (and lib fixed)
x-compressed-tar - 318.65 kB - 07/27/2020 at 06:07
Download
YGREC8_VHDL.20200723.tgz
Great progress on TAP (MUX64 / BBT-BC and Gray counter done)
x-compressed-tar - 263.17 kB - 07/22/2020 at 23:34
Download
YGREC8_VHDL.20200718.tgz
a few things work, TAP and ALU are in development...
x-compressed-tar - 241.87 kB - 07/18/2020 at 04:53
Download
INC8_ASIC_test.cjs
INC8 (version ASIC) with some test features
cjs - 5.08 kB - 07/15/2020 at 18:49
Download
CLA8_NAND.cjs
CircuitJS source code for the NANDified Carry Lookahead
cjs - 7.64 kB - 03/17/2020 at 00:05
Download
Add8.cjs
source code of the CLA8 for <a target="_blank" rel="noopener noreferrer" href="http://falstad.com/circuit">falstad.com/circuit</a>
cjs - 8.16 kB - 03/05/2020 at 23:24
Download
YGREC8_VHDL.20200119.tgz
Added FSM<br>ALU_2020 is bork, needs debug
x-compressed-tar - 143.02 kB - 01/19/2020 at 04:14
Download
YGREC8_VHDL.20200105.tgz
x-compressed-tar - 138.15 kB - 01/05/2020 at 05:34
Download
YGREC8_VHDL.20191231.tgz
Last release of 2019, new start for 2020 with the new, ASIC-friendly, ROP2 unit
x-compressed-tar - 119.74 kB - 12/31/2019 at 02:05
Download
FrontPanel_coords_4.dia
x-dia-diagram - 7.42 kB - 09/29/2019 at 05:07
Download
FrontPanel_coords_4_seri.dia
x-dia-diagram - 4.74 kB - 09/29/2019 at 05:07
Download
YGREC8_VHDL.20190422.3.tgz
R7 decoder in A3P tiles
x-compressed-tar - 174.65 kB - 04/22/2019 at 01:39
Download
YGREC8_VHDL.20190422.tgz
a better decoder for the register set
x-compressed-tar - 173.01 kB - 04/21/2019 at 17:58
Download
YGREC8_VHDL.20190421.tgz
Redesigning the register set
x-compressed-tar - 155.92 kB - 04/21/2019 at 00:13
Download
YGREC8_VHDL.20190412.tgz
New gates library, better ALU and decoder
x-compressed-tar - 152.59 kB - 04/11/2019 at 23:23
Download
YGREC8_VHDL.20190404.tgz
more versions of the ALU8 decoder
x-compressed-tar - 148.85 kB - 04/04/2019 at 23:10
Download
YGREC8_VHDL.20190401.tgz
spun off the decoder logic for deglitching
x-compressed-tar - 144.44 kB - 04/01/2019 at 02:57
Download
YGREC8_VHDL.20190328.tgz
ALU implemented as 3-input logic gates
x-compressed-tar - 143.44 kB - 03/28/2019 at 20:20
Download
YGREC8_VHDL.20190325.tgz
ALU redesigned
x-compressed-tar - 109.39 kB - 03/25/2019 at 05:22
Download
YGREC8_OpcodeMap_v2.svg
AND and XOR swapped for the new ALU design
svg+xml - 24.80 kB - 03/23/2019 at 01:09
Preview
YGREC8_VHDL.20190317.tgz
new assembler/disassembler in VHDL
x-compressed-tar - 101.43 kB - 03/17/2019 at 02:53
Download
YGREC8_InstructionFormat_v7.svg
svg+xml - 11.40 kB - 01/13/2019 at 23:30
Preview
YGREC8_OpcodeMap_v1.svg
svg+xml - 24.80 kB - 01/13/2019 at 22:24
Preview
YGREC8_VHDL.20190101.tgz
assembly passes self-tests
x-compressed-tar - 114.55 kB - 01/01/2019 at 15:25
Download
YGREC8_VHDL.20181230.tgz
assembler reboot, not finished but promising !
x-compressed-tar - 113.57 kB - 12/30/2018 at 07:05
Download
YGREC8_VHDL.20181101.zip
Added the proasic3 VHDL library for rough gate-level simulations, many incoherent or obsolete files though.
Zip Archive - 109.48 kB - 11/01/2018 at 16:04
Download
YGREC8_InstructionFormat_v5.svg
V5 with Imm4 field
svg+xml - 10.89 kB - 11/01/2018 at 15:59
Preview
YGREC8_VHDL.20181017.tgz
Added the ProASIC3 &quot;tiles&quot; library
x-compressed-tar - 60.71 kB - 10/17/2018 at 04:14
Download
ygrec8_20180116_yg.svg
Core diagram in SVG, added LDCx MUXes
svg+xml - 17.96 kB - 01/17/2018 at 17:38
Preview
YGREC8_InstructionFormat_v3.svg
Imm9 removed
svg+xml - 6.99 kB - 01/12/2018 at 18:57
Preview
YGREC8_VHDL.20171209.tgz
Added: license, readme, mustfail...
x-compressed-tar - 36.61 kB - 12/08/2017 at 23:21
Download
ygrec8.nanorc
Coloration syntaxique pour l&apos;&#xE9;diteur de texte Nano
nanorc - 1.16 kB - 12/08/2017 at 14:43
Download
ygrec_debug.svg
How the YGREC8 is split and controlled for debug, development and test
svg+xml - 8.55 kB - 12/03/2017 at 16:26
Preview
ygrec8_20171122_yg.svg
core diagram in SVG
svg+xml - 16.46 kB - 12/03/2017 at 16:26
Preview
YGREC8_InstructionFormat_v2.svg
Instruction format diagram in SVG
svg+xml - 7.50 kB - 12/03/2017 at 16:16
Preview
YGREC8_VHDL.20171117.tgz
Starting to code the assembler.
x-compressed-tar - 19.08 kB - 11/17/2017 at 09:51
Download
YGREC8_VHDL.20171116.tgz
Executes its first instructions, and other enahncements
x-compressed-tar - 16.41 kB - 11/16/2017 at 05:28
Download
YGREC8_VHDL.20171114.tgz
Added some BRAM blocks and ... a core ! (it compiles but need to be tested now)
x-compressed-tar - 14.65 kB - 11/14/2017 at 06:41
Download
YGREC8_VHDL.20171113.tgz
much better integration now.
x-compressed-tar - 9.38 kB - 11/13/2017 at 02:19
Download
YGREC8_VHDL.20171112.tgz
ALU, SHL, REG, INC8, INC16...
x-compressed-tar - 7.53 kB - 11/12/2017 at 05:22
Download
YGREC8_VHDL.20171111.tgz
ALU, SHL and REG units, with their testbenches and 2 versions each, targeted for A3P FPGA.
x-compressed-tar - 5.69 kB - 11/11/2017 at 14:49
Download
ALU8.tgz
2 versions of the ALU, one testbench and one script to run it all with GHDL.
application/x-compressed-tar - 2.33 kB - 11/10/2017 at 07:06
Download
