• 1
    INTRO:
    Making your project run well and look good can be hard. A couple years now I made my projects on perfboard but they didn't all worked well or looked good. Most projects looked confusing to the eye. But now I can make my projects work perfect, look great and in a relatively short time. This is because of the new online software EasyEDA. You can design your projects without downloading software. EasyEDA has a schematic designer, pcb-designer and even a simulation program. In this instructable I am going to teach you how to convert your old circuitboard into a high quality pcb and manufacture it professionally with EasyEDA and JLCPCB.
  • 2
    STEP 1: Creating a Schematic
    If you haven't made a schematic of your pcb you can do it right away with EasyEDA. You just have to create an account at www.easyeda.com . After you did that you can start making your projects. Hit the 'new schematic button' to create a schematic. On the left side you have the parts section and on the right side the properties of the part you selected and the wiring and drawing tools. You can use those to connect your parts into the specific order you want. First place all the parts you want and then hook them up to each other. Here I created a simple led circuit.
  • 3
    STEP 2: Converting Your Schematic Into a Pcb.
    If you have a large project that consists of a lot wiring then it can be handy to turn your circuitboard into a pcb. You can do that with EasyEDA. You can turn your schematic you made into one with on click on a button. I used a schematic of a project I am doing for school, it can look a bit confusing at first but when you design it yourself it is much easier. Just hit the 'convert project to PCB' button and your can start designing your pcb!
