Retrofit Radiator Robot
My apt has old radiators with valves. Adding thermostats was expensive, so I decided to add a motor around them.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I moved into an apartment whose heating system is pretty old.
It has only valves that you rotate with knobs, and no pins that you push with a thermostat. Also the heating is common in the whole building, so I can't just replace them, I'd have to call a company.
So I took this opportunity to try and build my own system, learn a few things and have some good maker fun.
