DIGITAL PROTOBOARD EURORACK
a small board for prototyping digital eurorack project
Being tired of perfboard full of wires I designed this modular board for easy and quick prototyping projects. The goal is to put together eurorack module using digital processor (STM32F030K6). It has a 2*12bit dac (MCP4822) (that can be changed for the MCP4802 as well), 6 (CV-able) inputs to the ADC and three outputs that can be connected to the PWM outputs or the DAC outputs. It also offers 4 logics output to the eurorack standard (10v).
The important fact was to create something that could be used for several projects and not having the remaining boards left unsued.
env_arm.pdf
schematic
Adobe Portable Document Format - 178.00 kB - 01/04/2018 at 13:01
Preview
  • 1 × STM32f030K6 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × MCP4822 Data Converters / Digital to Analog Converters (DACs)
  • 3 × MCP6002 Amplifier and Linear ICs / Operational Amplifiers
  • 1 × 2n3904 Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
