Hackaday.io Hackaday.io
Sign up Log in
Retro Wristwatch
The first digital watches had this red bubble display, you need to push a button to see the time.
saarbastlersaarbastler
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
753 followers
  • Description
  • Details
  • Files 0
  • Components 9
    • View all
  • Logs 0
  • Instructions 2
    • View all
  • Discussion 2
  • The 2018 Hackaday Prize
View Gallery
931
2
753
7
Team (1)
  • saarbastlersaarbastler
Join this project's team
  • RetroWristWatch
hardware
completed project
Software
3dprinting 2018hackadayprize
Related lists
2018 THP: Digikey Parts
Hackaday Prize entries using Digikey parts
2018 THP: Microchip Parts
Hackaday Prize entries using Microchip parts
2018 Prize: Time Lord Achievement
2018 Hackaday Prize Achievement: You project is a blast from the past! Retro looking projects or projects using actual old parts.
This project is submitted for
  • Coin Cell Challenge
  • Open Hardware Design Challenge
This project was created on 01/07/2018 and last updated 7 years ago.
Description
A four digit bubble display shows the time and date. An Atmega 328P and a DS1337 powered by a 2032 coin cell. The PCB has been milled on my Stepcraft 420. The case is printed using a RF1000 3D Printer. The Software is written "bare metal" using Atmel Studio 7. All files are published on my github account.
Components
  • 1 × Atmega 328P
  • 1 × DS1337 Clock and Timer ICs / Real-Time Clocks
  • 1 × 32,768KHz Quartz
  • 1 × 4 Digit bubble Display QDSP-6064
  • 4 × BC848B NPN Transistor
View all 9 components
Build Instructions
Collapse
  • 1
    Step 1
    See details on https://github.com/saarbastler/RetroWristWatch
  • 2
    Step 2
View all instructions
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
saarbastler wrote 01/13/2018 at 15:11 • point
Thanks for cour comment. I'm using the wristwatch since more than half a year, and it's still the first battery in.
But I started thinking about a charger. An external modified TP4056 should work. Something like the $1 Coin Cell Charger. I just need to add a connector for charging.
A build-in charger would consume a lot of space.
Mike Szczys wrote 01/11/2018 at 21:55 • point
I really like the look of these bubble displays and have been meaning to do a project with them. Your overall aesthetic on this one is quite pleasing... the bright blue body next to the copper clad is quite nice!
This would be great with a rechargeable coin cell and with the charger built-in.
Official Hackaday Prize Entry
A tilt and touch activated wristwatch using a "retro" style bubble 7 segment display.
Project Owner Contributor
Tilt Touch Time
skoogSkoog
Cistercian digital clock with minimalist display
CIS-4
danjovicdanjovic
A wordnum clock utilising a Microbit, RTC and 100 addressable RGB LEDs
WordNum Clock
uk4dshouseuk4dshouse
Easy 3D printable seven segment digit powered by 14 WS2812 LEDs.
"pxlDigit" - a 3D printed seven segment digit
fabianFabian
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Retro Wristwatch", please tell us the reason.
Send message
Remove Member
