MSP430 Minimal
Simple Small MSP430 Value Line Breakout Boad
I started to make a small breakout board for the MSP430 value line DIP processors (msp430g2452, msp430g2553, ...). The first test is a temperature control system with an DS18B20 temperature probe and an external relais. This code is based on https://github.com/dsiroky/OneWire . PCB and Code is available on github.
Board v1 available under (dirty cheap pcbs):
http://dirtypcbs.com/view.php?share=1062&accesskey=fa772e16543f8e868555ccbc2bad097e
Although I have to admit the silkscreen is not very informative and I would also flip perhaps the order for the voltage regulator.
  • 1 × PCB Board https://github.com/Lageos/msp430-minimal/tree/master/msp430-minimal-board
  • 1 × Push Button
  • 2 × 100 nF Ceramic Capacitor
  • 1 × 47k Resistor
  • 1 × MSP430G2553 / MSP4302452
View all 6 components
  • Another Fried Launchpad
    lageos10/19/2014 at 14:53 0 comments
    One call for caution, the MSP430 launchpads are great and inexpensive but you have to be careful if using it for programming external tools (ESD, voltage levels).
    Therfore a little hold on my project :)
    The good thing is a launchpad isn't expensive and delivery is free from https://estore.ti.com
  • Temp Control Running
    lageos10/15/2014 at 17:23 0 comments
    After some time waiting for my PCB (got it via dirty pcbs) I was able to start the first project: a simple temperature controler.
    A connected DS18B20 sensor determines the temperature and the microcontroler controls an external relais and subsequentially a peltier element.
    Currently in development is to set the processor in low power mode i.e. use interrupts and pwm for controling the relais.
    Next steps are to use a 8 pole dip switch to set the target temperature (fits nice in the breakout and avoid the need of an display) and uprgrade to a MOSFET or SSR.
    But it already works for keeping the coffee warm :)
    If you're interested the code (code composer studio project) as well as the board layout is available at github (encountered no problems yet which makes me proud for the first eagle desing I made).
    You can even order the board dircetly via:
View all 2 project logs
View all 7 instructions
