Before I had a 3D printer I had wanted to find a way to repair these headphones. Now that I actually have a printer, I figure it s a good time to take a shot at getting these back in working order. It isn't so much that the value of these are insanely high these days (I got good use out of them already), but they still will make good headphones for working out with. My goal is to test my design skill for 3d printed parts and attempt to retain as much of the OEM design as possible.
I am interested in being considered as a student entry in the "Repairs you can 3d print" project
FIrst log entry for the project includes the initial measurements of individual parts of the headphones, and a quick concept model. While tedious, this will pay off in the end as I want to have a full assembly in ONShape (all files will be open source) so I can visualize the assembly and reduce iteration. There really is an interesting approach to the design by the original designers to have swivel and extending features for the drivers. I want to maintain the original fit/form; as seen by the photos there are some tricky features which may require additional parts. The tricky features mainly consist of small indents for indexing of the driver in swivel and extension. This will be made more clear in future posts.
As always I try to keep number of parts in an assembly at a minimum. The idea I originally had was to have it all one piece, but some of these small details will require a multi part assembly.
Next step will be to draw a couple concepts on how I would like the assembly to go together. The best concept will be the one that both is relatively easy to print, assemble, and still maintain the extend/ swivel of the headphones.
Awesome! Can't wait to see where you go with this. Don't forget to click the "submit project to" on the left sidebar to officially enter this in the contest.
How did it end up? Can I please ask you if you can send me the 3D Drawings? Thank you
