All of us who work on Hackaday.io are reading your feedback. If we don't get back to you individually, know that we read what you wrote. Thanks for taking the time to give us feedback, we really appreciate it, you help improve the site every day!
Bugs, Feature Requests, Wishlists
I've feed this back to the developers. Thanks for highlighting it.
Today I noticed I can resize the PM reply window. Fantastic; thank you Jasmine and the team for listening to users ;-)
I just updated my project details for ramanPi and now the details are cut off WAY before my read more tag and where it always worked before... The whole thing was designed to be viewed in a contiguous line and now it just doesn't fit right... I know it is HUGE, but I'd really really like to have it cut off where I had it previously... Any chance of that being possible?
Hello fl@C@, I'm not sure why it's changed for you now. It should be cutting at just under 5k chars. That is a system wide restraint. The read more tag only works if you place it before the automatic cut off. If it's not behaving as it should, let me know and I raise a ticket. Cheers.
Not sure whether it's related, but my read-more tags all got messed-up one day. They worked fine one day, then the next my entire page got screwed-up, including sections I didn't edit. I tried to delete a couple and reinsert them, but no-go. Now they're just appearing as the text "---- more ----"
That's similar to what I am seeing.. in addition to it cutting off far before it has in the past... I also have a serious problem where I can edit text in one area and it deletes text in some random area ...typically the last place the cursor was if I click in another paragraph before editing.. I've accidentally deleted entire paragraphs without seeing until later because the text was 4 paragraphs below where I was typing...
@ and # fun:
A continuation of the @thing and #thing dilemma at #181. #MeArm - Pocket Sized Robot Arm 's givaway (at http://hackaday.io/project/181-mearm-pocket-sized-robot-arm/log/12633-hackaday-munich-mearm-giveaway/discussion-12243)
erm... I've done a bit of experimenting, since... (EDIT)
It seems to work as-expected now... I had hours of fail, and now that seems fine and other things seem quirky. Maybe it's a browser-thing. The key-factor, at least with my setup, is that you have to *type* the whole thing, basically without interruption (don't change windows/tabs to verify your spelling, don't *paste* anything, or arrow-up/down/left/right, or even scroll the window? And if you use backspace, cross your fingers.) Yes, (now) spaces work in @'s. Note, also, that the list is short, so make sure you know the *full* spelling of the user-name, whether it has a space, a dot, or a dash, etc., and keep typing until the name pops up. The list will disappear after the space, but pop-up again if you have the continued-spelling correct. Yes, this ordeal leaves me feeling a bit foolish... OTOH, I was in friggin' IT for nearly a decade, coding for nearly two, and *this* eluded me...?
Not sure whether this is browser-specific; I'm using Iceweasel (Mozilla) 24.6.0 on Debian Wheezy x86 (which I figured to be the culprit in many other text-entry/editing oddities I've experienced setting up my project-pages, instructions, etc... *and right here*).
Hey ericwazhung. Thanks for the experimenting. I've passed on those details to dev, and hopefully we can iron out some of the kinks soon. Much appreciated!
I can confirm this behavior on chrome(39.0.2171.95 64-bit)) on a mac book (10.8.5) "The list will disappear after the space, but pop-up again if you have the continued-spelling correct" - would be cool to have a search equivalent to "LIKE '%value%' " on mysql, where anything but alphabet characters gets ignored.
Hey there, replies on comments on logs of projects I don't follow don't show on my feed.
Cheers davedarko. Can you link me to an example comment thread and I'll put in a ticket for it.
It was your reply to be exact :) I am now following the project. I just noticed that your respond here also didn't show and I'm following this. But I can see you responding to other comments in my feed. http://hackaday.io/project/181-mearm-pocket-sized-robot-arm/log/12633-hackaday-munich-mearm-giveaway/discussion-12312?page=2#discussion-list
Just an idea:
When editing a project log, for example, I add a picture into it, I can scale it down by dragging the picure corner. That's great and I use this feature a lot in order to not overwhelm the reader by huge images.
It could be nice to have possibility to enlarge the picture again (some small icon in corner), or have it "clickable" when viewing the project log. By now, I can click right and select "view image" (in firefox), but it is not quite obvious for evaryone. The pictures in project header are better in this aspect, as they are clickable, leading to full size image.
Hey jaromir.sukuba, thanks for the idea. When we improve the image handling, we'll work something out.
I use the Chrome extension Imagus, which provides a full-size image on hover. That could be a good workaround for you (and it works on lots of other sites too).
For some reason my account has disassociated my email, github and twitter and so it is starting a new account for each. I am wondering if I have lost my account. I am tlankford01. I am a hackaday prize quaterfinalist with the Solar Power Anti-poaching UAV. I was wanting to add documentation. Thank you
Hello tlankford01, unfortunately if you signed up with email, you have to login using that email and password. If you try to sign in with twitter or github, it will create a new account for each of those.
We're going to work out some kind of account merging, but for the time being, please sign in the way you signed up.
I finished up my EDC contest entry and tried to get a few page views to my project, but it doesn't seem that the page view counter is working. I put files for the project up on thingiverse this morning which link back to hackaday.io, but the project views has not increased in the past 2 weeks. My thingiverse thing has 427 views since this morning and I would assume that at least one person clicked through to hackaday.io... Also I've gotten 2 skulls in the time period that I had no new page views.
EDC entry - https://hackaday.io/project/3580
Thingiverse - http://www.thingiverse.com/thing:618811
Hello Tim, we were trying out the pageviews feature, so at the moment it is manually updated intermittently. We hope to automate it soon.
imagine with me.... in the components section of a project build you have some script which automatically adds the prices of the components next to them. a total would be great too. i like to think you could get some revenue from dedicated suppliers for sending people their way. i know we all crave perfection but even as a rough price it'd be handy and probably an incentive for people to start a build. i just got all spastic for peter jansens tricorder, i would love one/a kit and in my mind something which helped a brother out in the planning department would be the push i needed to start getting excited.
We like the way you think. Keep sending us your ideas.
Would other people be up for a component pricing feature on hackaday.io?
I'd like it, even if it's just an estimate. Project creators would have to be able to fix pricing errors, though, maybe with just a manual price field that overrides the estimate.
How do I add many images in my project log or instructions section...
I have a lot of images and currently I have to upload one by one... so it is a very painfully slow process.
Am I missing something..?
Hello Zaid, no you are not missing anything. Apart from the 6 images you can put up when you create/edit your project, we don't have a gallery feature at the moment. Sorry about that. It's definately something we'd like to improve in the future.
oh man, am not asking for a gallery, just a feature where I can select many pics at the same time from the file upload dialog and the images just come on the post one by one...I have many pics of my tiny bot line follower project but I am very lazy to upload each separately...
- but maybe I will have to for now... :(
Project page links for network type Github won't work on my page. Setting the link as network "other" works fine. When network is set to "Github" the links simply won't show. There seems to be place holder of sort, but no visible link.
EDIT: btw admins, I have added the link to the github page twice, once as network type github, again as type 'other', so only one link is showing where there should be two. Just clarifying in case you overlooked it as it might look like it is working because there is a link to github. The link is set to network type github and isn't showing.
Hey TTN, When I go to your project I can see three links in total: two links with the github icon (first & fifth links)and one with the other/star icon (sixth link).
Hi, I was (and still am) seeing the same thing in Firefox but not in Chrome. Initially I though my Firefox installation was broken because it was also misbehaving in other ways at that time. But since other users still seem to experience this (recent comment on #Laser Cut Mini Mill) I think it may be linked to Firefox (35.0.1 on Windows in my case). Hope this helps
Just curious, what is the hacker list http://hackaday.io/hackers sorting algorithm, when "sort by influence" (default) is selected? It was something like rank = A*number_of_projects + B*number_of_followers before, where A and B are some constants. Somehow I don't understand the new sorting.
By the way, 3 months ago I reported nothing regarding my own projects (comments, skulls, followers) in my feed, though visible in global feed. Any news regarding this?
Hey jaromir,
The new ranking algorithm (still work-in-progress and will likely change couple more times before stable) is graph-based, pretty much along the lines of Google PageRank - recursively defined as a function of scores of people that follow given user, etc. We're working on a new iteration that incorporates (and puts more weight on) user's projects and related activity. Once we converge to a "stable" solution that we like - we'll publish all the implementation details.
Regarding the personal projects not showing up in "my feed" - we're looking at it and will queue up the fix for the next release.
That's interesting info, thanks.
Regarding the "my feed" issue, it's fixed right now. Thank you all for your support.
[question] [component list]
If I type "foo" in the first line of a component entry and press [tab], the second line fills with "Electronic Components / Misc. Electronic Components" and whatever I type goes after that. If I type "RTC" (referring to a real-time clock) in the first line, the second line fills with "Potentiometers, Trimmers, Variable Resistors / Potentiometers". What's going on here?
Hello PointyOintment, we try to suggest suitable descriptions, but depending on what you enter it doesn't always match. You can just edit it yourself.
How about a minor edit flag/mode for typo's and forgotten additions that don't generate feeds/triggers etc?
We're working on getting rid of the duplicate updates in the feed, but a minor edit flag is a good idea too.
We just added this feature. You can now edit away on logs and details and stop it from updating the feed.
Another idea: it would be nice to have more than 5 lines in edit window, when writing private message. For me, it looks like this http://imgur.com/V27tcYe - a lot of empty space, with tiny window in the middle to write into.
