[images and videos are to be reuploaded]
[Component list will be added soon]
Tempo display
Since we want a precise time reference, it's better to use a quartz-based oscillator. But, on the other hand, we need to be able to change the oscillator frequency. Shall we use two oscillators then ? One as a clock reference, and the other one as an adjustable frequency ? That's exactly what I did! Indeed, the CD4553 is a 3-Digit BCD Counter, and it has four very useful inputs:- A clock input (CLK).
- A master reset input (RES).
- A latch enable input (LE).
- And a disable input (DIS).
![4060](http://freewebmaster.fr/figs/metro/4060.png)
Now that we have a reference clock at 32 Hz, we need to trigger the CD4553's inputs in the right order. The best thing to do is then to add a decimal counter between the CD4060 and the CD4553. Thanks to that, we will be able to trigger the different inputs sequentially.
So, what we want to do is:
- Disable the clock input of the CD4553 (DIS input)
- Set LE to zero, so we can memorise the new count, then set it back to one.
- Reset the counting (we are now ready to count).
- Set DIS to zero to finally count the pulses on the CLK input.
- Repeat from 1.
![4017](http://freewebmaster.fr/figs/metro/4017.png)
![4543](http://freewebmaster.fr/figs/metro/4543.png)
![555](http://freewebmaster.fr/figs/metro/555.png)
![555-freq](http://freewebmaster.fr/figs/metro/555-freq.png)
R1 = 1e3; R2 = 4.7e3; C = 100e-9; P = linspace(0, 10e3, 1000); Ra = R1; Rb = R2 + P; f = 1.44./(Ra + 2*Rb)/C; a = 100*(Ra + Rb)./(Ra + 2*Rb); figure(1) plot(P/1e3, f/6.4)...
:S''Since the CO output of the 4017 is actually a clock with a 50% duty
cycle and a 3.2 Hz frequency, the 4553 is counting pulses during 1/6.4
seconds. In other words, the displayed number will be given by CLK/6.4''
Why 6.4 seconds? I dont understand :S
