This project involves 5 "arcade" style buttons and an Adafruit Trinket M0. I made two versions of it, one is 3D printed with an acrylic panel, and the other is fully made cut pieces of acrylic. It could be laser cut(with the files provided) but I did it by hand with a miter saw. Its really simple and has many uses.
Details
Build video! I make two different versions.
Files
TinketHolder.stl
A Small holder for the trinket if you would like to use double sided tape to attach it to soemthing.
Standard Tesselated Geometry -
204.08 kB -
01/22/2018 at 16:00
Hello,
If I want to build this project in arduin uno, I think I should change pins 0,1 that correspond to those of TX RX?
