Xerox Phaser 3117 modified to print PCB
The goal of this project is to adapt an standard and commercial laser printer to allow direct printing over PCB
One of the most complex and hard work stages of enthusiast prototype development is the PCB manufacturing. Depending of the method used, It involves specific resources like acid, photo-resist PCB, acetone, developer substances, transfer paper, iron, extra pair of fingers to replace those who the iron burned, etc... So I decide make this process more simple and searching a little bit through google and YouTube, I found a lot of project like this, working very well and making easy the DIY users life, so I get an old printer from my job and started this project.
The strategy is perform a minimum intervention to the printer.
Since the printer is making what we want (put toner into a surface) we just have to change the surface type (PCB instead paper).
I divided this conversion in the follow stages:
I - Make the printer blind
The printer detects the paper and follow up the whole printing process using simple IR sensors that provide digital information to the main board, so in order to keep the original control system we should find the way to provide the same information that the IR sensors, we are talking about the timing in the signals that IR sensors provide.
The Service Manual of the Xerox Phaser 3117 provides a System Timing Chart for A4 format, but I strongly recommend get the timing from the real circuit helped by an oscilloscope.
The "blinding" process also include the Fusor stage deletion, from this stage we have a Thermistor sensor that is easy emulate with a 6.5k - 1/4W resistor, please refer to the schematics of this article for more information (Fusor deletion)
II - Mechanical adaptation
After make the printer blind, we can start with the mechanical adaptation. Since we have that the paper is following a "C" route we should adapt the printer in order to open a straight way to allow the PCB go through the printer.
III - Quality improvement
Now that we have the printer making the basic task (put toner on the PCB) we should focus on improve the quality of the toner layer to avoid holes and white lines. If we are working with an old printer is it possible we should replace the cartridge and continue with our lives, but in case you found very difficult get a new cartridge (because this model is recalling), an option is repair the old one (my case).
(it will continue ... )
IV - Input automation
The printer process starts with the "clutch" signal. In the original system this clutch signal powered a Solenoid in order to feed the paper into the printer. This time we are using this clutch signal in order to have a reference, a start point, to generate the emulated IR signals, so why not use the same reference to activate a servo in order to feed the printer with the PCB.
In the follow image you can see the circuit that generates the clunch signal.
The basic idea to adapt the printer to feed PCBs to the printer is the follow:
The follow image shows the position of the mechanical adaption and its location into the printer.
As I mentioned at the beginning of this article, we are trying to take advantage of the mechanical solutions already present in the printer, so on this time we are using the entrance paper guides in order to fix the new input platform.
  • 1 × Xerox Phaser 3117 Laser Printer
  • 1 × PIC12F675 Microcontroller
  • 1 × 4N35 Opto and Fiber Optic Semiconductors and ICs / Optocouplers and Optoisolators
  • 1 × Various resistors Electronic Components / Misc. Electronic Components
  • 1 × Cutter
View all 6 components
  • 1
    Step 1
    Disassembly of the Phaser 3117 to get the Main board accessible.
  • 2
    Step 2
    Install the emulator circuit in the upper side of the main board. (scheme and mounting images will be added soon)
  • 3
    Step 3
    Remove the main cover.
View all 7 instructions
RD wrote 06/06/2016 at 21:51 point
where are the valid links to download?
you could fix the download links?
