A Simple and cheap table saw hold down-in
Made from 3/4in ply, a few knobs bolts with small wheels directed 5 degrees to wards the fence, holds material down and eliminates lift up
1.5k views
How to prevent lift up and fly back against the table saw fence for all of $ 15.00 First you need a simple cross-cut sled, cross cut the blocks from 3/4in plywood
Some of the commercial units have the safety and anti-kick-back incorporated but at a cost, hence this cheapie system for plywood and a few knobs
the jimmy jig set up
JPEG Image - 314.92 kB - 02/03/2018 at 23:18
Preview
a jimmy jig on a Bosch table saw extends the rip width with less
JPEG Image - 310.72 kB - 02/03/2018 at 23:17
Preview
thinking out of the box
JPEG Image - 315.18 kB - 02/03/2018 at 23:16
Preview
anti-kickback
JPEG Image - 132.66 kB - 02/03/2018 at 23:15
Preview
anti-kick-back
JPEG Image - 125.63 kB - 02/03/2018 at 23:14
Preview
View all 32 files
  • 1 × With 3/4in plywood and a n anti-kick-spure this is fool proof
View all 4 project logs
  • 1
    simple safety additon to the table saw fence from plywood
    Nothing complicated with the use of plywood, knobs and bolts, easily copied from the videos and stills, size to suit your requirement
View all instructions
